[postgis-users] FW: Points and lines
Tuomas Ruohonen
illurt at hotmail.com
Thu Sep 17 01:44:22 PDT 2009
Hi all,
I have tried many different ways and i am not getting success.
Lets think that i am inserting rows to table and in table there is column the_geom, my insert sentence has lon and lat,
so everytime i insert into table this trigger is fired and it is doing points from lon and lat. In trigger i have now statement that FOR EACH STATEMENT execute...
But querys are still too slow (inserting like 200 rows), if i am doing that point upgrading by manually it is very fast. Should be something like the_geom = NEW.the_geom...
What i should do ?
To: postgis-users at postgis.refractions.net
Subject: RE: [postgis-users] Points and lines
Date: Tue, 8 Sep 2009 13:16:35 +0300
Lets think that i am inserting only rows to table, not updating any data.
These NEW and OLD pseudos are still helping me ?
Br.
Tuomas
> Date: Tue, 8 Sep 2009 10:17:58 +0100
> From: mark.cave-ayland at siriusit.co.uk
> Subject: Re: [postgis-users] Points and lines
> Tuomas Ruohonen wrote:
> > What is wrong in my function, it doesnt stop or should it take so
> > loooong... ? Minutes... Trying to insert to lines in table
> > CREATE OR REPLACE FUNCTION make_point() RETURNS TRIGGER AS $start_point$
> > BEGIN
> > UPDATE positionreports SET the_geom = SetSRID(st_makepoint
> > ("longitude","latitude"), 4326);
> > RETURN NULL; -- result is ignored since this is an AFTER trigger
> > END;
> > $start_point$ LANGUAGE plpgsql;
> > CREATE TRIGGER start_point
> > AFTER INSERT OR UPDATE ON positionreports
> > FOR EACH ROW EXECUTE PROCEDURE make_point();
> Look carefully at your stored procedure - you're updating the contents
> of the entire table every time someone modifies a single row.
> Take a look at the documentation here:
> http://www.postgresql.org/docs/8.4/interactive/plpgsql-trigger.html. You
> should be using the NEW and OLD pseudotypes to change to contents of a
> single row.
> HTH,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-users mailing list
Jaa muistosi verkossa haluamiesi henkilöiden kanssa haluamiesi henkilöiden kanssa.
_________________________________________________________________
Windows puhelimella saat enemmän vastinetta rahoillesi.
http://www.windowsmobile.fi
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090917/8268b403/attachment.html>
