[postgis-users] splitting a PostGIS db across multiple disks
Rick graham.rick at gmail.com
Tue Apr 6 08:19:38 PDT 2010
You can make multiple disks act like one using a method called striping.
Here is the first link I googled.  Apparently it will increase performance
as well...
http://insights.oetiker.ch/linux/raidoptimization/
On Tue, Apr 6, 2010 at 10:58 AM, Brian Modra <brian at zwartberg.com> wrote:
> On 06/04/2010, P Kishor <punk.kish at gmail.com> wrote:
> > I asked this question yesterday, and received a very helpful pointer
> > from Ben Madin re. TABLESPACES. As noted in my reply in that thread, I
> > am also investigating the possibility of splitting a single table
> > across multiple disks.
> > However, I am going to post this question in a different way in this new
> > thread.
> > Suppose I have a table FOO0 that stores info about every state in the
> > union. I know that some of these states will have mongo number of
> > rows, but I don't have to build all the states immediately. So, I
> > start with a few states' worth data, putting it in the default
> > /usr/local/pgsql/data location.
> > Then I start outgrowing that disk, and need to add another state, so I
> > add another disk, create a new tablespace, and create a new table
> > called FOO1 in this new tablespace. Then I can store the new states in
> > FOO1. As long as I break up my table into FOO0, FOO1, FOO2, and so on,
> > I can store each FOOn in a new tablespace. And, as long as I ensure
> > that each FOOn table contains a geographically consistent spatial
> > extent, I can build logic in my application to query the correct
> > table.
> > So, lets say 0 lon to -10 lon data are stored in FOO0, and -10 lon to
> > -20 lon in FOO1, then if the user requests data for -5 lon to -15 lon,
> > I will have to query both FOO0 and FOO1.
> If you split the data by lat-long extents, then you will need to also
> create duplicates of some of the data... anything that intersects the
> boundary must be duplicated...
> I assume you have a table with state boundaries in it?
> You could use this as an "index" to the table name. Then store a state
> per table...
> So when you do a spatial query, you first use the extent of the query
> to find which state(s) are withing/intersecting/contain the query
> area. Then you can generate one or more spatial queries to the tables
> containing the states data.
> > More work for me, but it is doable, no? Any insights on how to handle
> > something like this?
> yes
> > A corollary question -- are their any speed advantages to actually
> > creating multiple PostGIS instances, perhaps even splitting them
> > across multiple machines? Of course, it is going to be a pain in the
> > ass for me to maintain more than one instance of PostGres/PostGIS, so
> > I am not thrilled at that possibility. I'd rather have a single
> > instance just be managing data across multiple locations as required.
> Using multiple machines means that parallel retrievals are possible.
> It has to make it faster.
> ... but your idea of splitting data geographically probably makes this
> unlikely to happen in the majority of queries.
> Rather than split the data geographically, is there some property in
> the tables that can be used to split it up... so that certain rows
> (based on this key) go to different tables?
> This may result in a better performance benefit, because a single
> spatial query will hit multiple databases, returning rows in parallel.
> But then again, all this depends on how you gather your data for a
> query... to make what I just described work, you'd have to execute
> multiple queries at once, i.e. multi-threading.
> > Puneet Kishor http://www.punkish.org
> > Carbon Model http://carbonmodel.org
> > Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> > Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
> > Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> > Assertions are politics; backing up assertions with evidence is science
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Brian Modra   Land line: +27 23 5411 462
> Mobile: +27 79 69 77 082
> 5 Jan Louw Str, Prince Albert, 6930
> Postal: P.O. Box 2, Prince Albert 6930
> South Africa
> http://www.zwartberg.com/
Cheers!
Rick
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100406/2436bc67/attachment.html>
