[postgis-users] splitting a PostGIS db across multiple disks
Chris Hermansen chris.hermansen at timberline.ca
Tue Apr 6 08:22:38 PDT 2010
What about using RAID?  No data reorganization necessary.
http://wiki.postgresql.org/wiki/Community_Disk_Tuning_Guide
As the above notes, disk performance (eg spindle speed) is important.
Also, to get good performance, you need to understand your application's
performance needs.  Do you have a lot of small queries, etc etc.  If you
don't understand your application's performance needs, then you may be
better off running your application for awhile and measuring its
bottlenecks before you decide on a storage strategy.
P Kishor wrote:
> I asked this question yesterday, and received a very helpful pointer
> from Ben Madin re. TABLESPACES. As noted in my reply in that thread, I
> am also investigating the possibility of splitting a single table
> across multiple disks.
> However, I am going to post this question in a different way in this new thread.
> Suppose I have a table FOO0 that stores info about every state in the
> union. I know that some of these states will have mongo number of
> rows, but I don't have to build all the states immediately. So, I
> start with a few states' worth data, putting it in the default
> /usr/local/pgsql/data location.
> Then I start outgrowing that disk, and need to add another state, so I
> add another disk, create a new tablespace, and create a new table
> called FOO1 in this new tablespace. Then I can store the new states in
> FOO1. As long as I break up my table into FOO0, FOO1, FOO2, and so on,
> I can store each FOOn in a new tablespace. And, as long as I ensure
> that each FOOn table contains a geographically consistent spatial
> extent, I can build logic in my application to query the correct
> table.
> So, lets say 0 lon to -10 lon data are stored in FOO0, and -10 lon to
> -20 lon in FOO1, then if the user requests data for -5 lon to -15 lon,
> I will have to query both FOO0 and FOO1.
> More work for me, but it is doable, no? Any insights on how to handle
> something like this?
> A corollary question -- are their any speed advantages to actually
> creating multiple PostGIS instances, perhaps even splitting them
> across multiple machines? Of course, it is going to be a pain in the
> ass for me to maintain more than one instance of PostGres/PostGIS, so
> I am not thrilled at that possibility. I'd rather have a single
> instance just be managing data across multiple locations as required.
Regards,
Chris Hermansen    ·    mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.840.4625
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
