[postgis-users] st_max_distance - This function is unimplemented yet
Birgit Laggner
birgit.laggner at vti.bund.de
Wed Apr 7 06:23:32 PDT 2010
Hallo Nicklas,
ahhhh, ok, this explains everything...
Thanks a lot! Regards,
Birgit.
On 07.04.2010 14:50, Nicklas Avén wrote:
> Hallo Birgit
> The max distance function was actually not implemented until version 1.5
> There were some ideas about the function earlier that by some reason
> made the sql-part of the function exist.
> But now it is there, so the recomendation is, upgrade to PostGIS
> 1.5.1. The function has also changed name so now it is called
> ST_Maxdistance
> http://postgis.org/documentation/manual-1.5/ST_MaxDistance.html
> Hope that helps
> Nicklas
> 2010-04-07 Birgit Laggner wrote:
> Dear list,
> >when I try to use the function st_max_distance(), I get the following
> error:
> >ERROR: This function is unimplemented yet
> >SQL Status:XX000
> >I am using PostGIS Version 1.3.6 and the geometries, I try to get the
> >max distance for, are linestrings.
> >St_max_distance and max_distance are both listed in my functions list in
> >the postgresql database.
> >Am I doing something wrong?
> >Regards,
> >Birgit.
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100407/43994f61/attachment.html>
