[postgis-users] st_union
strk
strk at keybit.net
Tue Apr 13 13:33:01 PDT 2010
I was having similar issues with unioning country boundaries
from the gadm dataset [1], and was thinking how would snaprounding
deal with the issue (ie: what brings in, what dangers introduces).
What do you think Martin ?
Maybe it'd be worth exposing the snapping version more, possibly
taking a tolerance explicitly.
[1] http://www.gadm.org/
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
On Tue, Apr 13, 2010 at 09:05:07AM -0700, Martin Davis wrote:
> PostGIS (actually GEOS, which mirrors JTS) doesn't use a tolerance
> during geometry union operations. It's possible that Arc does, which is
> why you're seeing a difference.
> What this indicates is that your data is not 100% cleanly noded. You
> could try snapping all your data to a small-size grid - that can
> sometimes fix problems of this sort. Although it may also introduce
> gaps...
> Lee wrote:
> > Hi all, First post but have been lurking for a long time.
> >In the process of migrating some geoprocessing procedures over to our open
> >source stack, I came across a difference in results from postgis' st_union
> >vs. arcgis' dissolve. From what I can tell these functions should be
> >synonymous in theory, despite their naming. (?)
> >It seems like st_union is not doing a "clean" union, some slivers are
> >remaining.
> >Original parcel fabric: http://quimby.ca/original.jpg
> >Dissolved by ArcGIS: http://quimby.ca/dissolved_by_arcgis.jpg
> >st_union by postgis: http://quimby.ca/dissolved_by_postgis.jpg
> >The input to both functions was the same table in postgis. I am defining
> >the geometry simply as select
> >st_union(current_assessment_parcel.the_geom) AS the_geom
> >Postgresql 8.4.1
> >Postgis 1.4
> >Is this simply a difference in tolerance? or am I seeing something else
> >here.
> >Thanks,
> >Lee.
