[postgis-users] st_area and 0.001953125
Birgit Laggner birgit.laggner at vti.bund.de
Thu Apr 15 05:07:45 PDT 2010
Hi Maxime,
well, this would argue against the guess from Marc regarding the
versions change from 1.4.0 to 1.4.1 (I can't imagine that 1.5.1 has
errors that were already debugged in 1.4.1). What catches my eye is that
all systems that show the error are 64-bit systems and the one from Marc
providing the true result is a 32-bit system. Maybe this could be
leading to an explanation??
Thanks  and regards,
Birgit.
On 15.04.2010 13:48, Maxime van Noppen wrote:
> On 04/15/2010 01:37 PM, Marc Jansen wrote:
>> Hi Birgit,
>> I can confirm your results on
> To help tracking down the bug: I have the same problem (areas
> 0.001953125 or 0 for the query on the pastebin) on :
> PostgreSQL 8.4.3 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC)
> 4.4.3 20100316 (prerelease), 64-bit
> POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
> 2009" LIBXML="2.7.6" USE_STATS
