[postgis-users] st_area and 0.001953125 (Possible Bug)
Marc Jansen jansen at terrestris.de
Thu Apr 15 06:51:20 PDT 2010
Hi Birgit,
good catch. I am pretty sure this is some sort of a bug, possibly
related to 32-/64-bit architecture.
I opened a bug [1], and cced Birgit. Add comments there as you dig deeper.
Regards,
Marc
[1] http://trac.osgeo.org/postgis/ticket/503
Birgit Laggner wrote:
> Hi Maxime,
> well, this would argue against the guess from Marc regarding the
> versions change from 1.4.0 to 1.4.1 (I can't imagine that 1.5.1 has
> errors that were already debugged in 1.4.1). What catches my eye is that
> all systems that show the error are 64-bit systems and the one from Marc
> providing the true result is a 32-bit system. Maybe this could be
> leading to an explanation??
> Thanks  and regards,
> Birgit.
> On 15.04.2010 13:48, Maxime van Noppen wrote:
>> On 04/15/2010 01:37 PM, Marc Jansen wrote:
>>> Hi Birgit,
>>> I can confirm your results on
>> To help tracking down the bug: I have the same problem (areas
>> 0.001953125 or 0 for the query on the pastebin) on :
>> PostgreSQL 8.4.3 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC)
>> 4.4.3 20100316 (prerelease), 64-bit
>> POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
>> 2009" LIBXML="2.7.6" USE_STATS
> postgis-users mailing list
  Dipl.-Geogr. Marc Jansen
  - Anwendungsentwickler -
  terrestris GmbH & Co. KG
  Irmintrudisstraße 17
  53111 Bonn
  Tel:    ++49 (0)228 / 96 28 99 -53
  Fax:    ++49 (0)228 / 96 28 99 -57
  Email:  jansen at terrestris.de
  Web:    http://www.terrestris.de
  Amtsgericht Bonn, HRA 6835
  Komplementärin:  terrestris Verwaltungsgesellschaft mbH
  vertreten durch: Hinrich Paulsen, Till Adams
