[postgis-users] Build errors in MAC OSX
Paul Ramsey pramsey at cleverelephant.ca
Mon Apr 26 12:50:45 PDT 2010
How did you get the source, you seem to be missing files entirely...
P
On Mon, Apr 26, 2010 at 12:49 PM, John Connors <jconnors at berkeley.edu> wrote:
> Paul, you were right, there was a permissions error, but I fixed that and
> I am still getting these errors:
> make[1]: *** [g_box.o] Error 1
> make: *** [liblwgeom] Error 2
> The full log follows.
> Thanks,
> John
> Macintosh:postgis-1.5.1 postgres$ make
> make -C liblwgeom
> gcc -g -O2  -fno-common -DPIC  -Wall -Wmissing-prototypes  -c -o g_box.o
> g_box.c
> g_box.c:12:21: error: libgeom.h: No such file or directory
> g_box.c:16: error: syntax error before '*' token
> g_box.c:16: error: syntax error before 'flags'
> g_box.c:17: warning: return type defaults to 'int'
> g_box.c:17: warning: no previous prototype for 'gbox_new'
> g_box.c: In function 'gbox_new':
> g_box.c:18: error: 'GBOX' undeclared (first use in this function)
> g_box.c:18: error: (Each undeclared identifier is reported only once
> g_box.c:18: error: for each function it appears in.)
> g_box.c:18: error: 'g' undeclared (first use in this function)
> g_box.c:18: error: syntax error before ')' token
> g_box.c:19: error: 'flags' undeclared (first use in this function)
> g_box.c: At top level:
> g_box.c:23: warning: type defaults to 'int' in declaration of 'POINT3D'
> g_box.c:23: error: syntax error before '*' token
> g_box.c:24: warning: no previous prototype for 'gbox_merge_point3d'
> g_box.c: In function 'gbox_merge_point3d':
> g_box.c:25: error: 'gbox' undeclared (first use in this function)
> g_box.c:25: error: 'p' undeclared (first use in this function)
> g_box.c:31: error: 'G_SUCCESS' undeclared (first use in this function)
> g_box.c:34: warning: type defaults to 'int' in declaration of 'GBOX'
> g_box.c:34: error: syntax error before '*' token
> g_box.c:35: warning: no previous prototype for 'gbox_contains_point3d'
> g_box.c: In function 'gbox_contains_point3d':
> g_box.c:36: error: 'gbox' undeclared (first use in this function)
> g_box.c:36: error: 'pt' undeclared (first use in this function)
> g_box.c:39: error: 'LW_FALSE' undeclared (first use in this function)
> g_box.c:41: error: 'LW_TRUE' undeclared (first use in this function)
> g_box.c:44: warning: type defaults to 'int' in declaration of 'GBOX'
> g_box.c:44: error: syntax error before '*' token
> g_box.c:45: warning: no previous prototype for 'gbox_merge'
> g_box.c: In function 'gbox_merge':
> g_box.c:46: warning: implicit declaration of function 'assert'
> g_box.c:46: error: 'merge_box' undeclared (first use in this function)
> g_box.c:48: error: 'new_box' undeclared (first use in this function)
> g_box.c:49: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:56: warning: implicit declaration of function 'FLAGS_GET_Z'
> g_box.c:56: warning: implicit declaration of function 'FLAGS_GET_GEODETIC'
> g_box.c:61: warning: implicit declaration of function 'FLAGS_GET_M'
> g_box.c:67: error: 'G_SUCCESS' undeclared (first use in this function)
> g_box.c:70: warning: type defaults to 'int' in declaration of 'GBOX'
> g_box.c:70: error: syntax error before '*' token
> g_box.c:71: warning: no previous prototype for 'gbox_overlaps'
> g_box.c: In function 'gbox_overlaps':
> g_box.c:74: error: 'g1' undeclared (first use in this function)
> g_box.c:74: error: 'g2' undeclared (first use in this function)
> g_box.c:78: warning: implicit declaration of function 'lwerror'
> g_box.c:83: error: 'LW_FALSE' undeclared (first use in this function)
> g_box.c:94: error: 'LW_TRUE' undeclared (first use in this function)
> g_box.c:101: error: syntax error before '*' token
> g_box.c:102: warning: return type defaults to 'int'
> g_box.c:102: warning: no previous prototype for 'gbox_from_string'
> g_box.c: In function 'gbox_from_string':
> g_box.c:105: warning: implicit declaration of function 'strstr'
> g_box.c:105: warning: incompatible implicit declaration of built-in
> function 'strstr'
> g_box.c:106: error: 'GBOX' undeclared (first use in this function)
> g_box.c:106: error: 'gbox' undeclared (first use in this function)
> g_box.c:106: warning: implicit declaration of function 'gflags'
> g_box.c:129: warning: type defaults to 'int' in declaration of 'GBOX'
> g_box.c:129: error: syntax error before '*' token
> g_box.c:130: warning: no previous prototype for 'gbox_to_string'
> g_box.c: In function 'gbox_to_string':
> g_box.c:134: error: 'gbox' undeclared (first use in this function)
> g_box.c:135: warning: implicit declaration of function 'strdup'
> g_box.c:135: warning: incompatible implicit declaration of built-in
> function 'strdup'
> g_box.c:137: warning: implicit declaration of function 'lwalloc'
> g_box.c:141: warning: implicit declaration of function 'snprintf'
> g_box.c:141: warning: incompatible implicit declaration of built-in
> function 'snprintf'
> g_box.c:146: warning: incompatible implicit declaration of built-in
> function 'snprintf'
> g_box.c:151: warning: incompatible implicit declaration of built-in
> function 'snprintf'
> g_box.c:156: warning: incompatible implicit declaration of built-in
> function 'snprintf'
> g_box.c:159: warning: incompatible implicit declaration of built-in
> function 'snprintf'
> g_box.c:163: error: syntax error before '*' token
> g_box.c:163: warning: type defaults to 'int' in declaration of 'GBOX'
> g_box.c:164: warning: return type defaults to 'int'
> g_box.c:164: warning: no previous prototype for 'gbox_copy'
> g_box.c: In function 'gbox_copy':
> g_box.c:165: error: 'GBOX' undeclared (first use in this function)
> g_box.c:165: error: 'copy' undeclared (first use in this function)
> g_box.c:165: error: syntax error before ')' token
> g_box.c:166: warning: implicit declaration of function 'memcpy'
> g_box.c:166: warning: incompatible implicit declaration of built-in
> function 'memcpy'
> g_box.c:166: error: 'box' undeclared (first use in this function)
> g_box.c:170: warning: type defaults to 'int' in declaration of 'GBOX'
> g_box.c:170: error: syntax error before '*' token
> g_box.c:171: warning: no previous prototype for 'gbox_duplicate'
> g_box.c: In function 'gbox_duplicate':
> g_box.c:172: error: 'duplicate' undeclared (first use in this function)
> g_box.c:174: error: 'original' undeclared (first use in this function)
> g_box.c:195: error: syntax error before 'flags'
> g_box.c:196: warning: no previous prototype for 'gbox_serialized_size'
> g_box.c: In function 'gbox_serialized_size':
> g_box.c:197: warning: implicit declaration of function 'FLAGS_GET_BBOX'
> g_box.c:197: error: 'flags' undeclared (first use in this function)
> g_box.c:201: warning: implicit declaration of function 'FLAGS_NDIMS'
> g_box.c:204: warning: type defaults to 'int' in declaration of
> 'GSERIALIZED'
> g_box.c:204: error: syntax error before '*' token
> g_box.c:205: warning: no previous prototype for 'gbox_from_gserialized'
> g_box.c: In function 'gbox_from_gserialized':
> g_box.c:208: error: 'g' undeclared (first use in this function)
> g_box.c:208: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:211: error: 'gbox' undeclared (first use in this function)
> g_box.c:231: error: 'G_SUCCESS' undeclared (first use in this function)
> g_box.c:250: warning: implicit declaration of function 'LWDEBUG'
> g_box.c:251: warning: implicit declaration of function
> 'gserialized_calculate_gbox_geocentric_p'
> g_box.c:264: error: syntax error before 'p1'
> g_box.c: In function 'lwcircle_calculate_gbox':
> g_box.c:273: error: 'POINT4D' undeclared (first use in this function)
> g_box.c:273: error: 'center' undeclared (first use in this function)
> g_box.c:278: warning: implicit declaration of function 'lwcircle_center'
> g_box.c:278: error: 'p1' undeclared (first use in this function)
> g_box.c:278: error: 'p2' undeclared (first use in this function)
> g_box.c:278: error: 'p3' undeclared (first use in this function)
> g_box.c:279: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:310: warning: implicit declaration of function 'FP_LT'
> g_box.c:310: warning: implicit declaration of function 'FP_GT'
> g_box.c:340: warning: implicit declaration of function 'LWDEBUGF'
> g_box.c:421: warning: implicit declaration of function 'FP_MIN'
> g_box.c:423: warning: implicit declaration of function 'FP_MAX'
> g_box.c:431: error: 'gbox' undeclared (first use in this function)
> g_box.c:447: error: 'G_SUCCESS' undeclared (first use in this function)
> g_box.c:450: warning: type defaults to 'int' in declaration of
> 'POINTARRAY'
> g_box.c:450: error: syntax error before '*' token
> g_box.c:451: warning: no previous prototype for 'ptarray_calculate_gbox'
> g_box.c: In function 'ptarray_calculate_gbox':
> g_box.c:453: error: 'POINT4D' undeclared (first use in this function)
> g_box.c:453: error: syntax error before 'p'
> g_box.c:454: error: 'gbox' undeclared (first use in this function)
> g_box.c:457: error: 'pa' undeclared (first use in this function)
> g_box.c:457: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:460: warning: implicit declaration of function 'getPoint4d_p'
> g_box.c:460: error: 'p' undeclared (first use in this function)
> g_box.c:486: error: 'G_SUCCESS' undeclared (first use in this function)
> g_box.c:489: error: syntax error before '*' token
> g_box.c: In function 'lwcircstring_calculate_gbox':
> g_box.c:491: error: 'uchar' undeclared (first use in this function)
> g_box.c:491: error: syntax error before 'flags'
> g_box.c:492: error: 'GBOX' undeclared (first use in this function)
> g_box.c:493: error: 'POINT4D' undeclared (first use in this function)
> g_box.c:496: error: 'curve' undeclared (first use in this function)
> g_box.c:496: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:499: error: 'tmp' undeclared (first use in this function)
> g_box.c:499: error: 'flags' undeclared (first use in this function)
> g_box.c:502: error: 'gbox' undeclared (first use in this function)
> g_box.c:507: error: 'p1' undeclared (first use in this function)
> g_box.c:508: error: 'p2' undeclared (first use in this function)
> g_box.c:509: error: 'p3' undeclared (first use in this function)
> g_box.c:517: error: 'G_SUCCESS' undeclared (first use in this function)
> g_box.c:520: error: syntax error before '*' token
> g_box.c: In function 'lwpoint_calculate_gbox':
> g_box.c:522: error: 'point' undeclared (first use in this function)
> g_box.c:522: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:523: error: 'gbox' undeclared (first use in this function)
> g_box.c:526: error: syntax error before '*' token
> g_box.c: In function 'lwline_calculate_gbox':
> g_box.c:528: error: 'line' undeclared (first use in this function)
> g_box.c:528: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:529: error: 'gbox' undeclared (first use in this function)
> g_box.c:532: error: syntax error before '*' token
> g_box.c: In function 'lwpoly_calculate_gbox':
> g_box.c:534: error: 'poly' undeclared (first use in this function)
> g_box.c:534: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:537: error: 'gbox' undeclared (first use in this function)
> g_box.c:540: error: syntax error before '*' token
> g_box.c: In function 'lwcollection_calculate_gbox':
> g_box.c:542: error: 'GBOX' undeclared (first use in this function)
> g_box.c:542: error: syntax error before 'subbox'
> g_box.c:544: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:545: error: 'LW_TRUE' undeclared (first use in this function)
> g_box.c:546: error: 'coll' undeclared (first use in this function)
> g_box.c:550: error: 'subbox' undeclared (first use in this function)
> g_box.c:550: error: 'gbox' undeclared (first use in this function)
> g_box.c:554: warning: implicit declaration of function
> 'lwgeom_calculate_gbox'
> g_box.c:554: error: 'LWGEOM' undeclared (first use in this function)
> g_box.c:554: error: syntax error before ')' token
> g_box.c:563: error: 'LW_FALSE' undeclared (first use in this function)
> g_box.c:569: error: 'G_SUCCESS' undeclared (first use in this function)
> g_box.c:575: warning: type defaults to 'int' in declaration of 'LWGEOM'
> g_box.c:575: error: syntax error before '*' token
> g_box.c:576: warning: no previous prototype for 'lwgeom_calculate_gbox'
> g_box.c: In function 'lwgeom_calculate_gbox':
> g_box.c:577: error: 'lwgeom' undeclared (first use in this function)
> g_box.c:577: error: 'G_FAILURE' undeclared (first use in this function)
> g_box.c:579: warning: implicit declaration of function 'TYPE_GETTYPE'
> g_box.c:581: error: 'POINTTYPE' undeclared (first use in this function)
> g_box.c:582: error: 'LWPOINT' undeclared (first use in this function)
> g_box.c:582: error: syntax error before ')' token
> g_box.c:583: error: 'LINETYPE' undeclared (first use in this function)
> g_box.c:584: error: 'LWLINE' undeclared (first use in this function)
> g_box.c:584: error: syntax error before ')' token
> g_box.c:585: error: 'CIRCSTRINGTYPE' undeclared (first use in this
> function)
> g_box.c:586: error: 'LWCIRCSTRING' undeclared (first use in this function)
> g_box.c:586: error: syntax error before ')' token
> g_box.c:587: error: 'POLYGONTYPE' undeclared (first use in this function)
> g_box.c:588: error: 'LWPOLY' undeclared (first use in this function)
> g_box.c:588: error: syntax error before ')' token
> g_box.c:589: error: 'COMPOUNDTYPE' undeclared (first use in this function)
> g_box.c:590: error: 'CURVEPOLYTYPE' undeclared (first use in this
> function)
> g_box.c:591: error: 'MULTIPOINTTYPE' undeclared (first use in this
> function)
> g_box.c:592: error: 'MULTILINETYPE' undeclared (first use in this
> function)
> g_box.c:593: error: 'MULTICURVETYPE' undeclared (first use in this
> function)
> g_box.c:594: error: 'MULTIPOLYGONTYPE' undeclared (first use in this
> function)
> g_box.c:595: error: 'MULTISURFACETYPE' undeclared (first use in this
> function)
> g_box.c:596: error: 'COLLECTIONTYPE' undeclared (first use in this
> function)
> g_box.c:597: error: 'LWCOLLECTION' undeclared (first use in this function)
> g_box.c:597: error: syntax error before ')' token
> On Mon, 26 Apr 2010 11:43:34 -0700, Paul Ramsey
> <pramsey at cleverelephant.ca>
> wrote:
>> Sorry,
>> cd liblwgeom ; touch test
>> On Mon, Apr 26, 2010 at 11:25 AM, John Connors <jconnors at berkeley.edu>
>> wrote:
>>> Paul,
>>> Thanks for your reply. Running 'touch test' successfully creates a file
>>> called test.
>>> Does the info from the make offer any hints?
>>> Macintosh:postgis-1.5.1 postgres$ sudo ./configure
>>> --with-pgconfig=../bin/pg_config
> --with-geosconfig=../../../Frameworks/GEOS.framework/Versions/3/Programs/geos-config
>>> --with-projdir=../../../Frameworks/PROJ.framework/unix
>>> checking build system type... powerpc-apple-darwin9.8.0
>>> checking host system type... powerpc-apple-darwin9.8.0
>>> checking for gcc... gcc
>>> checking for C compiler default output file name... a.out
>>> checking whether the C compiler works... yes
>>> checking whether we are cross compiling... no
>>> checking for suffix of executables...
>>> checking for suffix of object files... o
>>> checking whether we are using the GNU C compiler... yes
>>> checking whether gcc accepts -g... yes
>>> checking for gcc option to accept ISO C89... none needed
>>> checking for a sed that does not truncate output... /usr/bin/sed
>>> checking for grep that handles long lines and -e... /usr/bin/grep
>>> checking for egrep... /usr/bin/grep -E
>>> checking for fgrep... /usr/bin/grep -F
>>> checking for ld used by gcc...
>>> /usr/libexec/gcc/powerpc-apple-darwin9/4.0.1/ld
>>> checking if the linker
> (/usr/libexec/gcc/powerpc-apple-darwin9/4.0.1/ld)
>>> is GNU ld... no
>>> checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -p
>>> checking the name lister (/usr/bin/nm -p) interface... BSD nm
>>> checking whether ln -s works... yes
>>> checking the maximum length of command line arguments... 196608
>>> checking whether the shell understands some XSI constructs... yes
>>> checking whether the shell understands "+="... yes
>>> checking for /usr/libexec/gcc/powerpc-apple-darwin9/4.0.1/ld option to
>>> reload object files... -r
>>> checking how to recognize dependent libraries... pass_all
>>> checking for ar... ar
>>> checking for strip... strip
>>> checking for ranlib... ranlib
>>> checking command to parse /usr/bin/nm -p output from gcc object... ok
>>> checking for dsymutil... dsymutil
>>> checking for nmedit... nmedit
>>> checking for lipo... lipo
>>> checking for otool... otool
>>> checking for otool64... no
>>> checking for -single_module linker flag... yes
>>> checking for -exported_symbols_list linker flag... yes
>>> checking how to run the C preprocessor... gcc -E
>>> checking for ANSI C header files... yes
>>> checking for sys/types.h... yes
>>> checking for sys/stat.h... yes
>>> checking for stdlib.h... yes
>>> checking for string.h... yes
>>> checking for memory.h... yes
>>> checking for strings.h... yes
>>> checking for inttypes.h... yes
>>> checking for stdint.h... yes
>>> checking for unistd.h... yes
>>> checking for dlfcn.h... yes
>>> checking for objdir... .libs
>>> checking if gcc supports -fno-rtti -fno-exceptions... no
>>> checking for gcc option to produce PIC... -fno-common -DPIC
>>> checking if gcc PIC flag -fno-common -DPIC works... yes
>>> checking if gcc static flag -static works... no
>>> checking if gcc supports -c -o file.o... yes
>>> checking if gcc supports -c -o file.o... (cached) yes
>>> checking whether the gcc linker
>>> (/usr/libexec/gcc/powerpc-apple-darwin9/4.0.1/ld) supports shared
>>> libraries... yes
>>> checking dynamic linker characteristics... darwin9.8.0 dyld
>>> checking how to hardcode library paths into programs... immediate
>>> checking whether stripping libraries is possible... yes
>>> checking if libtool supports shared libraries... yes
>>> checking whether to build shared libraries... yes
>>> checking whether to build static libraries... yes
>>> checking for gcc... (cached) gcc
>>> checking whether we are using the GNU C compiler... (cached) yes
>>> checking whether gcc accepts -g... (cached) yes
>>> checking for gcc option to accept ISO C89... (cached) none needed
>>> checking for g++... g++
>>> checking whether we are using the GNU C++ compiler... yes
>>> checking whether g++ accepts -g... yes
>>> checking whether we are using the GNU C++ compiler... (cached) yes
>>> checking whether g++ accepts -g... (cached) yes
>>> checking how to run the C++ preprocessor... g++ -E
>>> checking for ld used by g++...
>>> is GNU ld... no
>>> checking whether the g++ linker
>>> libraries... yes
>>> checking for g++ option to produce PIC... -fno-common -DPIC
>>> checking if g++ PIC flag -fno-common -DPIC works... yes
>>> checking if g++ static flag -static works... no
>>> checking if g++ supports -c -o file.o... yes
>>> checking if g++ supports -c -o file.o... (cached) yes
>>> libraries... yes
>>> checking if g++ supports -Wall... yes
>>> checking if g++ supports -Wmissing-prototypes... yes
>>> checking if g++ supports -ffloat-store... yes
>>> checking for flex... flex
>>> checking lex output file root... lex.yy
>>> checking lex library... -lfl
>>> checking whether yytext is a pointer... yes
>>> checking for bison... bison -y
>>> checking ieeefp.h usability... no
>>> checking ieeefp.h presence... no
>>> checking for ieeefp.h... no
>>> checking for convert... no
>>> configure: WARNING: ImageMagick does not seem to be installed.
>>> Documentation cannot be built
>>> checking for xsltproc... /usr/bin/xsltproc
>>> checking for dblatex... no
>>> configure: WARNING: dblatex is not installed so PDF documentation
> cannot
>>> be built
>>> configure: WARNING: could not locate Docbook stylesheets required to
>>> build
>>> the documentation
>>> checking CUnit/CUnit.h usability... no
>>> checking CUnit/CUnit.h presence... no
>>> checking for CUnit/CUnit.h... no
>>> configure: WARNING: could not locate CUnit required for liblwgeom unit
>>> tests
>>> checking iconv.h usability... yes
>>> checking iconv.h presence... yes
>>> checking for iconv.h... yes
>>> checking for libiconv_open in -liconv... yes
>>> Using user-specified pg_config file: ../bin/pg_config
>>> checking PostgreSQL version... PostgreSQL 8.4.3
>>> checking libpq-fe.h usability... yes
>>> checking libpq-fe.h presence... yes
>>> checking for libpq-fe.h... yes
>>> checking for PQserverVersion in -lpq... yes
>>> checking for xml2-config... /usr/bin/xml2-config
>>> checking libxml/tree.h usability... yes
>>> checking libxml/tree.h presence... yes
>>> checking for libxml/tree.h... yes
>>> checking libxml/parser.h usability... yes
>>> checking libxml/parser.h presence... yes
>>> checking for libxml/parser.h... yes
>>> checking libxml/xpath.h usability... yes
>>> checking libxml/xpath.h presence... yes
>>> checking for libxml/xpath.h... yes
>>> checking libxml/xpathInternals.h usability... yes
>>> checking libxml/xpathInternals.h presence... yes
>>> checking for libxml/xpathInternals.h... yes
>>> checking for xmlInitParser in -lxml2... yes
>>> Using user-specified geos-config file:
>>> checking GEOS version... 3.2.0
>>> checking geos_c.h usability... yes
>>> checking geos_c.h presence... yes
>>> checking for geos_c.h... yes
>>> checking for initGEOS in -lgeos_c... yes
>>> Using user-specified proj directory:
>>> checking proj_api.h usability... yes
>>> checking proj_api.h presence... yes
>>> checking for proj_api.h... yes
>>> checking for pj_get_release in -lproj... yes
>>> configure: creating ./config.status
>>> config.status: creating liblwgeom/Makefile
>>> config.status: creating liblwgeom/cunit/Makefile
>>> config.status: creating postgis/Makefile
>>> config.status: creating postgis/sqldefines.h
>>> config.status: creating loader/Makefile
>>> config.status: creating topology/Makefile
>>> config.status: creating regress/Makefile
>>> config.status: creating doc/Makefile
>>> config.status: creating doc/html/image_src/Makefile
>>> config.status: creating postgis_config.h
>>> config.status: executing libtool commands
>>>  PostGIS is now configured for powerpc-apple-darwin9.8.0
>>>  -------------- Compiler Info -------------
>>>  C compiler:           gcc -g -O2
>>>  C++ compiler:         g++ -g -O2
>>>  -------------- Dependencies --------------
>>>  GEOS config:
>>>  GEOS version:         3.2.0
>>>  PostgreSQL config:    ../bin/pg_config
>>>  PostgreSQL version:   PostgreSQL 8.4.3
>>>  PROJ4 version:        47
>>>  Libxml2 config:       /usr/bin/xml2-config
>>>  Libxml2 version:      2.6.16
>>>  PostGIS debug level:  0
>>>  -------- Documentation Generation --------
>>>  xsltproc:             /usr/bin/xsltproc
>>>  xsl style sheets:
>>>  dblatex:
>>>  convert:
>>> On Fri, 23 Apr 2010 19:46:44 -0700, Paul Ramsey
>>> wrote:
>>>> What happens when you run 'touch test'?
>>>> P
>>>> On Fri, Apr 23, 2010 at 5:33 PM, John Connors <jconnors at berkeley.edu>
>>>> wrote:
>>>>> I am trying to build the PostGIS 1.5 files in Mac OSX and I am
> getting
>>>>> the
>>>>> following error:
>>>>> make -C liblwgeom
>>>>> measures.o
>>>>> measures.c
>>>>> /var/tmp//ccyiv2X6.s:unknown:FATAL:can't create output file:
> measures.o
>>>>> make[1]: *** [measures.o] Error 1
>>>>> Any thoughts on how to deal with this?
>>>>> Thanks,
>>>>> John
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
