[postgis-users] Build errors in MAC OSX
John Connors
jconnors at berkeley.edu
Mon Apr 26 12:55:30 PDT 2010
Ok. That's what I thought. I downloaded the source from KyngChaos.
-John
On Mon, 26 Apr 2010 12:50:45 -0700, Paul Ramsey
<pramsey at cleverelephant.ca>
wrote:
> How did you get the source, you seem to be missing files entirely...
> P
> On Mon, Apr 26, 2010 at 12:49 PM, John Connors <jconnors at berkeley.edu>
> wrote:
>> Paul, you were right, there was a permissions error, but I fixed that
and
>> I am still getting these errors:
>> make[1]: *** [g_box.o] Error 1
>> make: *** [liblwgeom] Error 2
>> The full log follows.
>> Thanks,
>> John
>> Macintosh:postgis-1.5.1 postgres$ make
>> make -C liblwgeom
>> gcc -g -O2 -fno-common -DPIC -Wall -Wmissing-prototypes -c -o
g_box.o
>> g_box.c
>> g_box.c:12:21: error: libgeom.h: No such file or directory
>> g_box.c:16: error: syntax error before '*' token
>> g_box.c:16: error: syntax error before 'flags'
>> g_box.c:17: warning: return type defaults to 'int'
>> g_box.c:17: warning: no previous prototype for 'gbox_new'
>> g_box.c: In function 'gbox_new':
>> g_box.c:18: error: 'GBOX' undeclared (first use in this function)
>> g_box.c:18: error: (Each undeclared identifier is reported only once
>> g_box.c:18: error: for each function it appears in.)
>> g_box.c:18: error: 'g' undeclared (first use in this function)
>> g_box.c:18: error: syntax error before ')' token
>> g_box.c:19: error: 'flags' undeclared (first use in this function)
>> g_box.c: At top level:
>> g_box.c:23: warning: type defaults to 'int' in declaration of 'POINT3D'
>> g_box.c:23: error: syntax error before '*' token
>> g_box.c:24: warning: no previous prototype for 'gbox_merge_point3d'
>> g_box.c: In function 'gbox_merge_point3d':
>> g_box.c:25: error: 'gbox' undeclared (first use in this function)
>> g_box.c:25: error: 'p' undeclared (first use in this function)
>> g_box.c:31: error: 'G_SUCCESS' undeclared (first use in this function)
>> g_box.c:34: warning: type defaults to 'int' in declaration of 'GBOX'
>> g_box.c:34: error: syntax error before '*' token
>> g_box.c:35: warning: no previous prototype for 'gbox_contains_point3d'
>> g_box.c: In function 'gbox_contains_point3d':
>> g_box.c:36: error: 'gbox' undeclared (first use in this function)
>> g_box.c:36: error: 'pt' undeclared (first use in this function)
>> g_box.c:39: error: 'LW_FALSE' undeclared (first use in this function)
>> g_box.c:41: error: 'LW_TRUE' undeclared (first use in this function)
>> g_box.c:44: warning: type defaults to 'int' in declaration of 'GBOX'
>> g_box.c:44: error: syntax error before '*' token
>> g_box.c:45: warning: no previous prototype for 'gbox_merge'
>> g_box.c: In function 'gbox_merge':
>> g_box.c:46: warning: implicit declaration of function 'assert'
>> g_box.c:46: error: 'merge_box' undeclared (first use in this function)
>> g_box.c:48: error: 'new_box' undeclared (first use in this function)
>> g_box.c:49: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:56: warning: implicit declaration of function 'FLAGS_GET_Z'
>> 'FLAGS_GET_GEODETIC'
>> g_box.c:61: warning: implicit declaration of function 'FLAGS_GET_M'
>> g_box.c:67: error: 'G_SUCCESS' undeclared (first use in this function)
>> g_box.c:70: warning: type defaults to 'int' in declaration of 'GBOX'
>> g_box.c:70: error: syntax error before '*' token
>> g_box.c:71: warning: no previous prototype for 'gbox_overlaps'
>> g_box.c: In function 'gbox_overlaps':
>> g_box.c:74: error: 'g1' undeclared (first use in this function)
>> g_box.c:74: error: 'g2' undeclared (first use in this function)
>> g_box.c:78: warning: implicit declaration of function 'lwerror'
>> g_box.c:83: error: 'LW_FALSE' undeclared (first use in this function)
>> g_box.c:94: error: 'LW_TRUE' undeclared (first use in this function)
>> g_box.c:101: error: syntax error before '*' token
>> g_box.c:102: warning: return type defaults to 'int'
>> g_box.c:102: warning: no previous prototype for 'gbox_from_string'
>> g_box.c: In function 'gbox_from_string':
>> g_box.c:105: warning: implicit declaration of function 'strstr'
>> g_box.c:105: warning: incompatible implicit declaration of built-in
>> function 'strstr'
>> g_box.c:106: error: 'GBOX' undeclared (first use in this function)
>> g_box.c:106: error: 'gbox' undeclared (first use in this function)
>> g_box.c:106: warning: implicit declaration of function 'gflags'
>> g_box.c:129: warning: type defaults to 'int' in declaration of 'GBOX'
>> g_box.c:129: error: syntax error before '*' token
>> g_box.c:130: warning: no previous prototype for 'gbox_to_string'
>> g_box.c: In function 'gbox_to_string':
>> g_box.c:134: error: 'gbox' undeclared (first use in this function)
>> g_box.c:135: warning: implicit declaration of function 'strdup'
>> g_box.c:135: warning: incompatible implicit declaration of built-in
>> function 'strdup'
>> g_box.c:137: warning: implicit declaration of function 'lwalloc'
>> g_box.c:141: warning: implicit declaration of function 'snprintf'
>> g_box.c:141: warning: incompatible implicit declaration of built-in
>> function 'snprintf'
>> g_box.c:146: warning: incompatible implicit declaration of built-in
>> function 'snprintf'
>> g_box.c:151: warning: incompatible implicit declaration of built-in
>> function 'snprintf'
>> g_box.c:156: warning: incompatible implicit declaration of built-in
>> function 'snprintf'
>> g_box.c:159: warning: incompatible implicit declaration of built-in
>> function 'snprintf'
>> g_box.c:163: error: syntax error before '*' token
>> g_box.c:163: warning: type defaults to 'int' in declaration of 'GBOX'
>> g_box.c:164: warning: return type defaults to 'int'
>> g_box.c:164: warning: no previous prototype for 'gbox_copy'
>> g_box.c: In function 'gbox_copy':
>> g_box.c:165: error: 'GBOX' undeclared (first use in this function)
>> g_box.c:165: error: 'copy' undeclared (first use in this function)
>> g_box.c:165: error: syntax error before ')' token
>> g_box.c:166: warning: implicit declaration of function 'memcpy'
>> g_box.c:166: warning: incompatible implicit declaration of built-in
>> function 'memcpy'
>> g_box.c:166: error: 'box' undeclared (first use in this function)
>> g_box.c:170: warning: type defaults to 'int' in declaration of 'GBOX'
>> g_box.c:170: error: syntax error before '*' token
>> g_box.c:171: warning: no previous prototype for 'gbox_duplicate'
>> g_box.c: In function 'gbox_duplicate':
>> g_box.c:172: error: 'duplicate' undeclared (first use in this function)
>> g_box.c:174: error: 'original' undeclared (first use in this function)
>> g_box.c:195: error: syntax error before 'flags'
>> g_box.c:196: warning: no previous prototype for 'gbox_serialized_size'
>> g_box.c: In function 'gbox_serialized_size':
>> g_box.c:197: warning: implicit declaration of function 'FLAGS_GET_BBOX'
>> g_box.c:197: error: 'flags' undeclared (first use in this function)
>> g_box.c:201: warning: implicit declaration of function 'FLAGS_NDIMS'
>> g_box.c:204: warning: type defaults to 'int' in declaration of
>> 'GSERIALIZED'
>> g_box.c:204: error: syntax error before '*' token
>> g_box.c:205: warning: no previous prototype for 'gbox_from_gserialized'
>> g_box.c: In function 'gbox_from_gserialized':
>> g_box.c:208: error: 'g' undeclared (first use in this function)
>> g_box.c:208: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:211: error: 'gbox' undeclared (first use in this function)
>> g_box.c:231: error: 'G_SUCCESS' undeclared (first use in this function)
>> g_box.c:250: warning: implicit declaration of function 'LWDEBUG'
>> g_box.c:251: warning: implicit declaration of function
>> 'gserialized_calculate_gbox_geocentric_p'
>> g_box.c:264: error: syntax error before 'p1'
>> g_box.c: In function 'lwcircle_calculate_gbox':
>> g_box.c:273: error: 'POINT4D' undeclared (first use in this function)
>> g_box.c:273: error: 'center' undeclared (first use in this function)
>> g_box.c:278: warning: implicit declaration of function
'lwcircle_center'
>> g_box.c:278: error: 'p1' undeclared (first use in this function)
>> g_box.c:278: error: 'p2' undeclared (first use in this function)
>> g_box.c:278: error: 'p3' undeclared (first use in this function)
>> g_box.c:279: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:310: warning: implicit declaration of function 'FP_LT'
>> g_box.c:310: warning: implicit declaration of function 'FP_GT'
>> g_box.c:340: warning: implicit declaration of function 'LWDEBUGF'
>> g_box.c:421: warning: implicit declaration of function 'FP_MIN'
>> g_box.c:423: warning: implicit declaration of function 'FP_MAX'
>> g_box.c:431: error: 'gbox' undeclared (first use in this function)
>> g_box.c:447: error: 'G_SUCCESS' undeclared (first use in this function)
>> g_box.c:450: warning: type defaults to 'int' in declaration of
>> 'POINTARRAY'
>> g_box.c:450: error: syntax error before '*' token
>> g_box.c:451: warning: no previous prototype for
'ptarray_calculate_gbox'
>> g_box.c: In function 'ptarray_calculate_gbox':
>> g_box.c:453: error: 'POINT4D' undeclared (first use in this function)
>> g_box.c:453: error: syntax error before 'p'
>> g_box.c:454: error: 'gbox' undeclared (first use in this function)
>> g_box.c:457: error: 'pa' undeclared (first use in this function)
>> g_box.c:457: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:460: warning: implicit declaration of function 'getPoint4d_p'
>> g_box.c:460: error: 'p' undeclared (first use in this function)
>> g_box.c:486: error: 'G_SUCCESS' undeclared (first use in this function)
>> g_box.c:489: error: syntax error before '*' token
>> g_box.c: In function 'lwcircstring_calculate_gbox':
>> g_box.c:491: error: 'uchar' undeclared (first use in this function)
>> g_box.c:491: error: syntax error before 'flags'
>> g_box.c:492: error: 'GBOX' undeclared (first use in this function)
>> g_box.c:493: error: 'POINT4D' undeclared (first use in this function)
>> g_box.c:496: error: 'curve' undeclared (first use in this function)
>> g_box.c:496: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:499: error: 'tmp' undeclared (first use in this function)
>> g_box.c:499: error: 'flags' undeclared (first use in this function)
>> g_box.c:502: error: 'gbox' undeclared (first use in this function)
>> g_box.c:507: error: 'p1' undeclared (first use in this function)
>> g_box.c:508: error: 'p2' undeclared (first use in this function)
>> g_box.c:509: error: 'p3' undeclared (first use in this function)
>> g_box.c:517: error: 'G_SUCCESS' undeclared (first use in this function)
>> g_box.c:520: error: syntax error before '*' token
>> g_box.c: In function 'lwpoint_calculate_gbox':
>> g_box.c:522: error: 'point' undeclared (first use in this function)
>> g_box.c:522: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:523: error: 'gbox' undeclared (first use in this function)
>> g_box.c:526: error: syntax error before '*' token
>> g_box.c: In function 'lwline_calculate_gbox':
>> g_box.c:528: error: 'line' undeclared (first use in this function)
>> g_box.c:528: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:529: error: 'gbox' undeclared (first use in this function)
>> g_box.c:532: error: syntax error before '*' token
>> g_box.c: In function 'lwpoly_calculate_gbox':
>> g_box.c:534: error: 'poly' undeclared (first use in this function)
>> g_box.c:534: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:537: error: 'gbox' undeclared (first use in this function)
>> g_box.c:540: error: syntax error before '*' token
>> g_box.c: In function 'lwcollection_calculate_gbox':
>> g_box.c:542: error: 'GBOX' undeclared (first use in this function)
>> g_box.c:542: error: syntax error before 'subbox'
>> g_box.c:544: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:545: error: 'LW_TRUE' undeclared (first use in this function)
>> g_box.c:546: error: 'coll' undeclared (first use in this function)
>> g_box.c:550: error: 'subbox' undeclared (first use in this function)
>> g_box.c:550: error: 'gbox' undeclared (first use in this function)
>> g_box.c:554: warning: implicit declaration of function
>> 'lwgeom_calculate_gbox'
>> g_box.c:554: error: 'LWGEOM' undeclared (first use in this function)
>> g_box.c:554: error: syntax error before ')' token
>> g_box.c:563: error: 'LW_FALSE' undeclared (first use in this function)
>> g_box.c:569: error: 'G_SUCCESS' undeclared (first use in this function)
>> g_box.c:575: warning: type defaults to 'int' in declaration of 'LWGEOM'
>> g_box.c:575: error: syntax error before '*' token
>> g_box.c:576: warning: no previous prototype for 'lwgeom_calculate_gbox'
>> g_box.c: In function 'lwgeom_calculate_gbox':
>> g_box.c:577: error: 'lwgeom' undeclared (first use in this function)
>> g_box.c:577: error: 'G_FAILURE' undeclared (first use in this function)
>> g_box.c:579: warning: implicit declaration of function 'TYPE_GETTYPE'
>> g_box.c:581: error: 'POINTTYPE' undeclared (first use in this function)
>> g_box.c:582: error: 'LWPOINT' undeclared (first use in this function)
>> g_box.c:582: error: syntax error before ')' token
>> g_box.c:583: error: 'LINETYPE' undeclared (first use in this function)
>> g_box.c:584: error: 'LWLINE' undeclared (first use in this function)
>> g_box.c:584: error: syntax error before ')' token
>> g_box.c:585: error: 'CIRCSTRINGTYPE' undeclared (first use in this
>> function)
>> g_box.c:586: error: 'LWCIRCSTRING' undeclared (first use in this
>> function)
>> g_box.c:586: error: syntax error before ')' token
>> g_box.c:587: error: 'POLYGONTYPE' undeclared (first use in this
function)
>> g_box.c:588: error: 'LWPOLY' undeclared (first use in this function)
>> g_box.c:588: error: syntax error before ')' token
>> g_box.c:589: error: 'COMPOUNDTYPE' undeclared (first use in this
>> function)
>> g_box.c:590: error: 'CURVEPOLYTYPE' undeclared (first use in this
>> function)
>> g_box.c:591: error: 'MULTIPOINTTYPE' undeclared (first use in this
>> function)
>> g_box.c:592: error: 'MULTILINETYPE' undeclared (first use in this
>> function)
>> g_box.c:593: error: 'MULTICURVETYPE' undeclared (first use in this
>> function)
>> g_box.c:594: error: 'MULTIPOLYGONTYPE' undeclared (first use in this
>> function)
>> g_box.c:595: error: 'MULTISURFACETYPE' undeclared (first use in this
>> function)
>> g_box.c:596: error: 'COLLECTIONTYPE' undeclared (first use in this
>> function)
>> g_box.c:597: error: 'LWCOLLECTION' undeclared (first use in this
>> function)
>> g_box.c:597: error: syntax error before ')' token
>> On Mon, 26 Apr 2010 11:43:34 -0700, Paul Ramsey
>> wrote:
>>> Sorry,
>>> cd liblwgeom ; touch test
>>> On Mon, Apr 26, 2010 at 11:25 AM, John Connors <jconnors at berkeley.edu>
>>> wrote:
>>>> Paul,
>>>> Thanks for your reply. Running 'touch test' successfully creates a
file
>>>> called test.
>>>> Does the info from the make offer any hints?
>>>> Macintosh:postgis-1.5.1 postgres$ sudo ./configure
>>>> --with-pgconfig=../bin/pg_config
--with-geosconfig=../../../Frameworks/GEOS.framework/Versions/3/Programs/geos-config
>>>> --with-projdir=../../../Frameworks/PROJ.framework/unix
>>>> checking build system type... powerpc-apple-darwin9.8.0
>>>> checking host system type... powerpc-apple-darwin9.8.0
>>>> checking for gcc... gcc
>>>> checking for C compiler default output file name... a.out
>>>> checking whether the C compiler works... yes
>>>> checking whether we are cross compiling... no
>>>> checking for suffix of executables...
>>>> checking for suffix of object files... o
>>>> checking whether we are using the GNU C compiler... yes
>>>> checking whether gcc accepts -g... yes
>>>> checking for gcc option to accept ISO C89... none needed
>>>> checking for a sed that does not truncate output... /usr/bin/sed
>>>> checking for grep that handles long lines and -e... /usr/bin/grep
>>>> checking for egrep... /usr/bin/grep -E
>>>> checking for fgrep... /usr/bin/grep -F
>>>> checking for ld used by gcc...
>>>> /usr/libexec/gcc/powerpc-apple-darwin9/4.0.1/ld
>>>> checking if the linker
>> (/usr/libexec/gcc/powerpc-apple-darwin9/4.0.1/ld)
>>>> is GNU ld... no
>>>> checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -p
>>>> checking the name lister (/usr/bin/nm -p) interface... BSD nm
>>>> checking whether ln -s works... yes
>>>> checking the maximum length of command line arguments... 196608
>>>> checking whether the shell understands some XSI constructs... yes
>>>> checking whether the shell understands "+="... yes
>>>> checking for /usr/libexec/gcc/powerpc-apple-darwin9/4.0.1/ld option
to
>>>> reload object files... -r
>>>> checking how to recognize dependent libraries... pass_all
>>>> checking for ar... ar
>>>> checking for strip... strip
>>>> checking for ranlib... ranlib
>>>> checking command to parse /usr/bin/nm -p output from gcc object... ok
>>>> checking for dsymutil... dsymutil
>>>> checking for nmedit... nmedit
>>>> checking for lipo... lipo
>>>> checking for otool... otool
>>>> checking for otool64... no
>>>> checking for -single_module linker flag... yes
>>>> checking for -exported_symbols_list linker flag... yes
>>>> checking how to run the C preprocessor... gcc -E
>>>> checking for ANSI C header files... yes
>>>> checking for sys/types.h... yes
>>>> checking for sys/stat.h... yes
>>>> checking for stdlib.h... yes
>>>> checking for string.h... yes
>>>> checking for memory.h... yes
>>>> checking for strings.h... yes
>>>> checking for inttypes.h... yes
>>>> checking for stdint.h... yes
>>>> checking for unistd.h... yes
>>>> checking for dlfcn.h... yes
>>>> checking for objdir... .libs
>>>> checking if gcc supports -fno-rtti -fno-exceptions... no
>>>> checking for gcc option to produce PIC... -fno-common -DPIC
>>>> checking if gcc PIC flag -fno-common -DPIC works... yes
>>>> checking if gcc static flag -static works... no
>>>> checking if gcc supports -c -o file.o... yes
>>>> checking if gcc supports -c -o file.o... (cached) yes
>>>> checking whether the gcc linker
>>>> (/usr/libexec/gcc/powerpc-apple-darwin9/4.0.1/ld) supports shared
>>>> libraries... yes
>>>> checking dynamic linker characteristics... darwin9.8.0 dyld
>>>> checking how to hardcode library paths into programs... immediate
>>>> checking whether stripping libraries is possible... yes
>>>> checking if libtool supports shared libraries... yes
>>>> checking whether to build shared libraries... yes
>>>> checking whether to build static libraries... yes
>>>> checking for gcc... (cached) gcc
>>>> checking whether we are using the GNU C compiler... (cached) yes
>>>> checking whether gcc accepts -g... (cached) yes
>>>> checking for gcc option to accept ISO C89... (cached) none needed
>>>> checking for g++... g++
>>>> checking whether we are using the GNU C++ compiler... yes
>>>> checking whether g++ accepts -g... yes
>>>> checking whether we are using the GNU C++ compiler... (cached) yes
>>>> checking whether g++ accepts -g... (cached) yes
>>>> checking how to run the C++ preprocessor... g++ -E
>>>> checking for ld used by g++...
>>>> is GNU ld... no
>>>> checking whether the g++ linker
>>>> libraries... yes
>>>> checking for g++ option to produce PIC... -fno-common -DPIC
>>>> checking if g++ PIC flag -fno-common -DPIC works... yes
>>>> checking if g++ static flag -static works... no
>>>> checking if g++ supports -c -o file.o... yes
>>>> checking if g++ supports -c -o file.o... (cached) yes
>>>> libraries... yes
>>>> checking if g++ supports -Wall... yes
>>>> checking if g++ supports -Wmissing-prototypes... yes
>>>> checking if g++ supports -ffloat-store... yes
>>>> checking for flex... flex
>>>> checking lex output file root... lex.yy
>>>> checking lex library... -lfl
>>>> checking whether yytext is a pointer... yes
>>>> checking for bison... bison -y
>>>> checking ieeefp.h usability... no
>>>> checking ieeefp.h presence... no
>>>> checking for ieeefp.h... no
>>>> checking for convert... no
>>>> configure: WARNING: ImageMagick does not seem to be installed.
>>>> Documentation cannot be built
>>>> checking for xsltproc... /usr/bin/xsltproc
>>>> checking for dblatex... no
>>>> configure: WARNING: dblatex is not installed so PDF documentation
>> cannot
>>>> be built
>>>> configure: WARNING: could not locate Docbook stylesheets required to
>>>> build
>>>> the documentation
>>>> checking CUnit/CUnit.h usability... no
>>>> checking CUnit/CUnit.h presence... no
>>>> checking for CUnit/CUnit.h... no
>>>> configure: WARNING: could not locate CUnit required for liblwgeom
unit
>>>> tests
>>>> checking iconv.h usability... yes
>>>> checking iconv.h presence... yes
>>>> checking for iconv.h... yes
>>>> checking for libiconv_open in -liconv... yes
>>>> Using user-specified pg_config file: ../bin/pg_config
>>>> checking PostgreSQL version... PostgreSQL 8.4.3
>>>> checking libpq-fe.h usability... yes
>>>> checking libpq-fe.h presence... yes
>>>> checking for libpq-fe.h... yes
>>>> checking for PQserverVersion in -lpq... yes
>>>> checking for xml2-config... /usr/bin/xml2-config
>>>> checking libxml/tree.h usability... yes
>>>> checking libxml/tree.h presence... yes
>>>> checking for libxml/tree.h... yes
>>>> checking libxml/parser.h usability... yes
>>>> checking libxml/parser.h presence... yes
>>>> checking for libxml/parser.h... yes
>>>> checking libxml/xpath.h usability... yes
>>>> checking libxml/xpath.h presence... yes
>>>> checking for libxml/xpath.h... yes
>>>> checking libxml/xpathInternals.h usability... yes
>>>> checking libxml/xpathInternals.h presence... yes
>>>> checking for libxml/xpathInternals.h... yes
>>>> checking for xmlInitParser in -lxml2... yes
>>>> Using user-specified geos-config file:
>>>> checking GEOS version... 3.2.0
>>>> checking geos_c.h usability... yes
>>>> checking geos_c.h presence... yes
>>>> checking for geos_c.h... yes
>>>> checking for initGEOS in -lgeos_c... yes
>>>> Using user-specified proj directory:
>>>> checking proj_api.h usability... yes
>>>> checking proj_api.h presence... yes
>>>> checking for proj_api.h... yes
>>>> checking for pj_get_release in -lproj... yes
>>>> configure: creating ./config.status
>>>> config.status: creating liblwgeom/Makefile
>>>> config.status: creating liblwgeom/cunit/Makefile
>>>> config.status: creating postgis/Makefile
>>>> config.status: creating postgis/sqldefines.h
>>>> config.status: creating loader/Makefile
>>>> config.status: creating topology/Makefile
>>>> config.status: creating regress/Makefile
>>>> config.status: creating doc/Makefile
>>>> config.status: creating doc/html/image_src/Makefile
>>>> config.status: creating postgis_config.h
>>>> config.status: executing libtool commands
>>>> PostGIS is now configured for powerpc-apple-darwin9.8.0
>>>> -------------- Compiler Info -------------
>>>> C compiler: gcc -g -O2
>>>> C++ compiler: g++ -g -O2
>>>> -------------- Dependencies --------------
>>>> GEOS config:
>>>> GEOS version: 3.2.0
>>>> PostgreSQL config: ../bin/pg_config
>>>> PostgreSQL version: PostgreSQL 8.4.3
>>>> PROJ4 version: 47
>>>> Libxml2 config: /usr/bin/xml2-config
>>>> Libxml2 version: 2.6.16
>>>> PostGIS debug level: 0
>>>> -------- Documentation Generation --------
>>>> xsltproc: /usr/bin/xsltproc
>>>> xsl style sheets:
>>>> dblatex:
>>>> convert:
>>>> On Fri, 23 Apr 2010 19:46:44 -0700, Paul Ramsey
>>>> wrote:
>>>>> What happens when you run 'touch test'?
>>>>> P
>>>>> On Fri, Apr 23, 2010 at 5:33 PM, John Connors
>>>>> wrote:
>>>>>> I am trying to build the PostGIS 1.5 files in Mac OSX and I am
>> getting
>>>>>> the
>>>>>> following error:
>>>>>> make -C liblwgeom
>>>>>> measures.o
>>>>>> measures.c
>>>>>> /var/tmp//ccyiv2X6.s:unknown:FATAL:can't create output file:
>> measures.o
>>>>>> make[1]: *** [measures.o] Error 1
>>>>>> Any thoughts on how to deal with this?
>>>>>> Thanks,
>>>>>> John
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
