[postgis-users] PostGIS as WPS?
Stefan Keller sfkeller at gmail.com
Thu Apr 29 11:26:38 PDT 2010
Dear Jorge, chèr Olivier
Thanks for your answers! I'll give Python a try.
Your, S.
2010/4/29 Jorge de Jesus <jorge.de-jesus at jrc.ec.europa.eu>:
> Hi Stefan
> Despite pyWPS being "GRASS oriented" there is no problem  on running
> (any) python code as a process, I am not certain what are your needs but
> you could program a process in just a few lines that would accept a SQL
> query as a WPS String Input and then have the output as WPS String of
> Complex (XML) ouput.
> It's up to you to write the process and define what input/output.
> If you have specific pyWPS questions it is better to use the its mailing
> list (http://lists.wald.intevation.org/mailman/listinfo/pywps-devel)
> Jorge
> Olivier Courtin wrote:
>> On Apr 29, 2010, at 2:00 AM, Stefan Keller wrote:
>> Hi Stefan,
>>> General question: Are there projects around to turn PostGIS/PostgreSQL
>>> into a Web Processing Service (WPS)?
>>> I'm thinking of an approach similar to PyWPS which is a minimalist
>>> python wrapper code around GRASS.
>> Well PyWPS allow you to write in Python any treatment that you want.
>> And there's of course ways in Python to connect to PostgreSQL.
>> So you don't have to rewrite all the WPS part at all :)
>> Only few lines to do your own treatment with PostgreSQL/PostGIS.
>> HTH,
>> Olivier
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Jorge Samuel Mendes de Jesus (PhD)
> DG Joint Research Centre - European Commission
> Institute for Environment and Sustainability (IES)
> Global Environment Monitoring Unit (GEM)
> MOnitoring Of Natural resources for DEvelopment (MONDE)
> http://gem.jrc.ec.europa.eu
> Via Fermi 2749, TP 440,  I-21027 Ispra (VA), ITALY
> Tel : +39 0332 783536
> Fax : +39 0332 789960
> Email: jorge.de-jesus at jrc.ec.europa.eu
>       jorge.jesus at gmail.com
> OpenPGPKey: 0xE915CB1E
> "The views expressed are purely those of the writer and may not in any
> circumstances be regarded as stating an official position of the European
> Commission." (Disclaimer required under the terms and conditions of use of
> the internet and electronic mail from Commission equipment)"
