[postgis-users] How to setup a versioned datastore?
Lee
quimby5 at yahoo.com
Tue Aug 3 12:02:10 PDT 2010
For sure! I was just about to sit down this week and write something very
similar.
I grabbed it from SVN and trying to make it work on postgres8.4/postgis1.4. I
got as far as select postgis_enable_history(schema,table,geom) but get the
following error:
ERROR: more than one row returned by a subquery used as an expression
CONTEXT: SQL statement "SELECT (SELECT column_name FROM
information_schema.key_column_usage WHERE table_schema = $1 AND table_name =
$2 )"
PL/pgSQL function "postgis_enable_history" line 31 at assignment
I think maybe it doesn't account for tables with foreign keys?? As a test, I
tried this:
select * from information_schema.key_column_usage where table_schema='base' and
table_name = 'wtr_mainvalves'
"midlandgis_test";"base";"mainvalves_pkey";"midlandgis_test";"base";"wtr_mainvalves";"gid";1;
"midlandgis_test";"base";"mainvalves_owner_fkey";"midlandgis_test";"base";"wtr_mainvalves";"owner";1;1
"midlandgis_test";"base";"mainvalves_status_fkey";"midlandgis_test";"base";"wtr_mainvalves";"status";1;1
Furthermore, I tried enabling another table with no foreign keys - no problem
there.
Looking into the function code, it appears to be looking for a primary key to
use in the history table, but I can't immediately see an easy way to
differentiate between a pk and fk in the key_column table.
Anyone have any ideas?
Lee
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Tue, August 3, 2010 12:42:05 PM
Subject: Re: [postgis-users] How to setup a versioned datastore?
On Tue, Aug 3, 2010 at 12:17 PM, George Silva <georger.silva at gmail.com> wrote:
Hello Mark,
>Check the SVN
>http://svn.osgeo.org/postgis/tags/1.5.1/extras/history_table/
Wow! This looks like just the thing for me.
Thanks George.
Cheers!
Rick
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100803/a4680cd4/attachment.html>
