[postgis-users] How to setup a versioned datastore?
George Silva
georger.silva at gmail.com
Tue Aug 3 12:10:01 PDT 2010
Hello Lee, I'm glad it's "trying" to help you.
Yes, the function looks for the PK of each table, when you try yo enable it.
I'm at work right now, but an easy way to do it would be creating a function
which accepts the primary key field as a parameter, which was the original
design. I'll see if I can find an old version for it and I'll mail it to
you.
Furthermore, I'll try to fix this bug. Thanks for catching it.
Any other questions you might have, just drop me a line.
George
On Tue, Aug 3, 2010 at 4:02 PM, Lee <quimby5 at yahoo.com> wrote:
> For sure! I was just about to sit down this week and write something very
> similar.
> I grabbed it from SVN and trying to make it work on
> postgres8.4/postgis1.4. I got as far as select
> postgis_enable_history(schema,table,geom) but get the following error:
> ERROR: more than one row returned by a subquery used as an expression
> CONTEXT: SQL statement "SELECT (SELECT column_name FROM
> information_schema.key_column_usage WHERE table_schema = $1 AND table_name
> = $2 )"
> PL/pgSQL function "postgis_enable_history" line 31 at assignment
> I think maybe it doesn't account for tables with foreign keys?? As a test,
> I tried this:
> select * from information_schema.key_column_usage where table_schema='base'
> and table_name = 'wtr_mainvalves'
> "midlandgis_test";"base";"mainvalves_pkey";"midlandgis_test";"base";"wtr_mainvalves";"gid";1;
> "midlandgis_test";"base";"mainvalves_owner_fkey";"midlandgis_test";"base";"wtr_mainvalves";"owner";1;1
> "midlandgis_test";"base";"mainvalves_status_fkey";"midlandgis_test";"base";"wtr_mainvalves";"status";1;1
> Furthermore, I tried enabling another table with no foreign keys - no
> problem there.
> Looking into the function code, it appears to be looking for a primary key
> to use in the history table, but I can't immediately see an easy way to
> differentiate between a pk and fk in the key_column table.
> Anyone have any ideas?
> Lee
> *From:* Rick <graham.rick at gmail.com>
> *To:* PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> *Sent:* Tue, August 3, 2010 12:42:05 PM
> *Subject:* Re: [postgis-users] How to setup a versioned datastore?
> On Tue, Aug 3, 2010 at 12:17 PM, George Silva <georger.silva at gmail.com>wrote:
>> Hello Mark,
>> Check the SVN
>> http://svn.osgeo.org/postgis/tags/1.5.1/extras/history_table/
> Wow! This looks like just the thing for me.
> Thanks George.
> Cheers!
> Rick
> postgis-users mailing list
George R. C. Silva
Desenvolvimento em GIS
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100803/5f367942/attachment.html>
