[postgis-users] help setting up postgis
Edward Mac Gillavry emacgillavry at hotmail.com
Mon Aug 9 04:55:31 PDT 2010
Simply check the proper location of the  postgis.sql file. It should be in the directory where you installed postgis.
$ sudo updatedb
$ locate "postgis.sql"
/usr/src/postgis-1.5.1/postgis/postgis.sql
psql -d postgisdb -f /usr/src/postgis-1.5.1/postgis/postgis.sql
HTH
Edward
> Date: Mon, 9 Aug 2010 13:43:16 +0200
> From: fire at dubmosphere.de
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] help setting up postgis
> Dear all,
> I am running into some troubles trying to install postgis 1.5.1. After
> installation I followed the manual on which first steps to take. I
> created a postgresql db and did the createlang part.
> Now, when I enter "psql -d postgisdb -f postgis.sql" I get a
> "postgis.sql: No such file or directory" in return.
> What could be the problem? Where do I start looking?
> Regards,
> Jan
> ubuntu 9.10
> postgresql 8.4
> postGis 1.5.1
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100809/12cb1b2b/attachment.html>
