[postgis-users] help setting up postgis
Jan Saalbach fire at dubmosphere.de
Mon Aug 9 05:06:03 PDT 2010
Thank you Edward. It worked.
Which now leads me to another question. I have datasets of the form "x
y z". Which are location x,location y and elevation z to describe
different bathymetries . What is the smartes way to store them so they
can be easily worked with?
Regards,
Jan
Zitat von Edward Mac Gillavry <emacgillavry at hotmail.com>:
> Simply check the proper location of the  postgis.sql file. It should
> be in the directory where you installed postgis.
> $ sudo updatedb
> $ locate "postgis.sql"
> /usr/src/postgis-1.5.1/postgis/postgis.sql
> psql -d postgisdb -f /usr/src/postgis-1.5.1/postgis/postgis.sql
> HTH
> Edward
>> Date: Mon, 9 Aug 2010 13:43:16 +0200
>> From: fire at dubmosphere.de
>> To: postgis-users at postgis.refractions.net
>> Subject: [postgis-users] help setting up postgis
>> Dear all,
>> I am running into some troubles trying to install postgis 1.5.1. After
>> installation I followed the manual on which first steps to take. I
>> created a postgresql db and did the createlang part.
>> Now, when I enter "psql -d postgisdb -f postgis.sql" I get a
>> "postgis.sql: No such file or directory" in return.
>> What could be the problem? Where do I start looking?
>> Regards,
>> Jan
>> ubuntu 9.10
>> postgresql 8.4
>> postGis 1.5.1
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
