[postgis-users] pgsql2shp error
Jeff Adams
jadams at azavea.com
Tue Aug 10 05:36:25 PDT 2010
This doesn't explain or fix anything, but you could try using a temp table:
create table temp_for_export as select * from table1 where id < '20'
Then
pgsql2shp -f [path] -h [myhost] -p [port] -u [user] -P [password] [database]
temp_for_export
and see what that does.
Is there any chance your host, user or database is incorrect on the
pgsql2shp command line, so pgsql2shp is accessing a different "table1" than
you're looking at in the shell?
On Tue, Aug 10, 2010 at 6:44 AM, smas036 <sina.masoud.ansari at gmail.com>wrote:
> Update: The error is the same whether the column id is lower case or
> uppercase.
> Using single quotes 'id' produces a different error. Possibly an
> improvement:
> ERROR: Cannot determine geometry type (empty table).
> The dump works fine when a table is specified and there is no query,
> however
> there is a warning:
> WARNING: Cannot determine spatial reference (empty table or unknown spatial
> ref). No prj file will be generated.
> Any help is appreciated
> Sina
> http://old.nabble.com/pgsql2shp-error-tp29384180p29396396.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100810/dee2b160/attachment.html>
