[postgis-users] pgsql2shp error
smas036
sina.masoud.ansari at gmail.com
Wed Aug 11 02:50:25 PDT 2010
Thanks for the replies, the most promising command so far is:
pgsql2shp -f [path] -h [myhost] -p [port] -u [user] -P [password] [database]
"SELECT * FROM table1 WHERE 'ID' < '20'"
Which has the output:
Preparing table for user query... Done.
Initializing... WARNING: Cannot determine spatial reference (empty table or
unknown spatial ref). No prj file will be generated.
ERROR: Cannot determine geometry type (empty table)
I think the query is correct as other combinations if single and double
quotes around field values produce
"...column does not exist..." or "The system cannot find the file
specified."
I believe the command parameters before the query are correct as the command
without a query:
[table]
works fine.
It would be possible to produce a table from a query and use this command
but I wonder if there is a performance loss in doing so...
View this message in context: http://old.nabble.com/pgsql2shp-error-tp29384180p29406665.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
