[postgis-users] pgsql2shp error
Jeff Adams
jadams at azavea.com
Wed Aug 11 05:02:19 PDT 2010
Did you verify that the data in the shapefile is correct when you run the
command with just the table name?
Hang on a second... WHERE 'ID' < '20' is never true. That's why you're
getting an empty table. 'ID' is a string, as is '20'. I think you mean to
say where your ID column value is less than 20, correct? Single quotes mean
'this is a string'.
Are your ID values strings (varchars) or integers? If integers, it'll be
faster to use 20 as an integer (without the single quotes) rather than as a
string.
Maybe the problem is with 'id' by itself, so try fully qualifying it:
pgsql2shp -f [path] -h [myhost] -p [port] -u [user] -P [password] [database]
"SELECT * FROM table1 WHERE table1.id < 20"
On Wed, Aug 11, 2010 at 5:50 AM, smas036 <sina.masoud.ansari at gmail.com>wrote:
> Thanks for the replies, the most promising command so far is:
> [database]
> "SELECT * FROM table1 WHERE 'ID' < '20'"
> Which has the output:
> Preparing table for user query... Done.
> Initializing... WARNING: Cannot determine spatial reference (empty table or
> unknown spatial ref). No prj file will be generated.
> ERROR: Cannot determine geometry type (empty table)
> I think the query is correct as other combinations if single and double
> quotes around field values produce
> "...column does not exist..." or "The system cannot find the file
> specified."
> I believe the command parameters before the query are correct as the
> command
> without a query:
> [database]
> [table]
> works fine.
> It would be possible to produce a table from a query and use this command
> but I wonder if there is a performance loss in doing so...
> http://old.nabble.com/pgsql2shp-error-tp29384180p29406665.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
Jeff Adams
Azavea (formerly Avencia) | 340 N 12th St, Ste 402, Philadelphia, PA
jadams at azavea.com | T 215.701.7717 | F 215.925.2663
Web azavea.com | Blog azavea.com/blogs | Twitter
@azavea<http://twitter.com/azavea>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100811/6dd57f60/attachment.html>
