[postgis-users] making polygons from center + vertex
Francis Markham
fmarkham at gmail.com
Wed Aug 11 19:04:03 PDT 2010
Sure is, check out the ST_Buffer function
http://postgis.refractions.net/docs/ST_Buffer.html
ST_Buffer(geometry g1, float radius_of_buffer);
If you give it a point as g1, and the radius of the circle it will
calculate a pseduo-circular polygon for you. If you have two points
g1 and g2 you could use ST_Buffer(g1, ST_Distance(g1, g2));
-Francis
On 12 August 2010 11:36, Arnaud Sahuguet <arnaud.sahuguet at gmail.com> wrote:
> I found this really neat Google Maps example where you can draw polygons using 2 points: the center and one vertex.
> See http://www.barnabu.co.uk/geapi/polyplot/
> Is there a POST GIS function to create the corresponding polygon?
> regards,
> Arnaud Sahuguet
> postgis-users mailing list
