[postgis-users] making polygons from center + vertex
Arnaud Sahuguet arnaud.sahuguet at gmail.com
Wed Aug 11 19:30:10 PDT 2010
thanks.
Arnaud
On Wed, Aug 11, 2010 at 10:04 PM, Francis Markham <fmarkham at gmail.com>wrote:
> Sure is, check out the ST_Buffer function
> http://postgis.refractions.net/docs/ST_Buffer.html
>   ST_Buffer(geometry g1, float radius_of_buffer);
> If you give it a point as g1, and the radius of the circle it will
> calculate a pseduo-circular polygon for you.  If you have two points
> g1 and g2 you could use ST_Buffer(g1, ST_Distance(g1, g2));
> -Francis
> On 12 August 2010 11:36, Arnaud Sahuguet <arnaud.sahuguet at gmail.com>
> wrote:
> > I found this really neat Google Maps example where you can draw polygons
> using 2 points: the center and one vertex.
> > See http://www.barnabu.co.uk/geapi/polyplot/
> > Is there a POST GIS function to create the corresponding polygon?
> > regards,
> > Arnaud Sahuguet
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Arnaud Sahuguet
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100811/6fd6f6ec/attachment.html>
