[postgis-users] Routing with POSTGIS question
bdair2002 bdair2002 at gmail.com
Sun Aug 15 15:57:05 PDT 2010
Thank you very much, the reason I didn't ask in Pgrouting forum is that I
wanted another way to calculate route, when I downloaded the maps from
cloudmade, the roads wasn't in network shape, so I was thinking how do they
do their route, probably their road network is private.
on another topic, I see that osm2pgrouting works on linux (tested), and I
prefer to work with shp files since I did all the steps before, can you
point me to shp2pgrouting, I know it is possible using ARCGIS it self, but I
heard there is a tool called shp2pgrouting, if you can point me to it, it
would be great.
Sorry I am asking in routing, I should ask this in pgrouting.
Thanks in advance.
Daniel Kastl-3 wrote:
> For pgrouting you need to have a suitable road network and so you have to
> use osm2pgrouting for example to split your long OSM roads.
> If you want to know how cloudmade does, you probably need to ask them. But
> I
> don't think they take a raw OSM file as it is either.
> Daniel
> PS: you probably better ask on the pgRouting mailing list if you have
> pgRouting related questions
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> 2010/8/16 bdair2002 <bdair2002 at gmail.com>
>> Hello Guys,
>> I have used pgrouting with postgis, but I have noticed, when I downloaded
>> the maps from openstreemaps, I have noticed they don't use "segments for
>> the
>> street" meaning, the street has the same name in each intersection, and
>> no
>> start and end for the street.
>> My question is there a way to calculate the route when the table do not
>> have
>> start/ end point for each edge in the street? or should I convert it
>> using
>> pgrouting to make a road network? and how does cloudmade calculate their
>> routes if they don't have Edge points?
>> Thanks in advance.
>> View this message in context:
>> http://old.nabble.com/Routing-with-POSTGIS-question-tp29444252p29444252.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
View this message in context: http://old.nabble.com/Routing-with-POSTGIS-question-tp29444252p29445618.html
