[postgis-users] Routing with POSTGIS question
Daniel Kastl daniel at georepublic.de
Sun Aug 15 14:13:42 PDT 2010
For pgrouting you need to have a suitable road network and so you have to
use osm2pgrouting for example to split your long OSM roads.
If you want to know how cloudmade does, you probably need to ask them. But I
don't think they take a raw OSM file as it is either.
Daniel
PS: you probably better ask on the pgRouting mailing list if you have
pgRouting related questions
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
2010/8/16 bdair2002 <bdair2002 at gmail.com>
> Hello Guys,
> I have used pgrouting with postgis, but I have noticed, when I downloaded
> the maps from openstreemaps, I have noticed they don't use "segments for
> the
> street" meaning, the street has the same name in each intersection, and no
> start and end for the street.
> My question is there a way to calculate the route when the table do not
> have
> start/ end point for each edge in the street? or should I convert it using
> pgrouting to make a road network? and how does cloudmade calculate their
> routes if they don't have Edge points?
> Thanks in advance.
> http://old.nabble.com/Routing-with-POSTGIS-question-tp29444252p29444252.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100816/666027aa/attachment.html>
