[postgis-users] side location conflict GEOS touches() threw an error
David Epstein davideps at umich.edu
Wed Aug 18 19:26:16 PDT 2010
Hello,
I have a postGIS polygon layer with about 320,000 rows. I am trying to
return a table with object_number and the average area of the
surrounding (touching) polygons. I am getting this error:
NOTICE:  TopologyException: side location conflict 1.34593e+07 289017
ERROR:  GEOS touches() threw an error!
********** Error **********
SQL state: XX000
I have tried to simplify the geometry many different times. Nothing
seems to solve the problem. I can process the first 20,000 rows
(object_number < 20000) but something is causing problems after that. I
have pasted the script below, any suggestions would be welcomed!
Thank you,
-david
SELECT p1.ogc_fid, avg(p2.shape_area)
FROM parcels09_d3_v2_simplify as p1, parcels09_d3_v2_simplify as p2
WHERE st_touches(p1.wkb_geometry, p2.wkb_geometry)
GROUP BY p1.ogc_fid
ORDER BY p1.ogc_fid
