[postgis-users] side location conflict GEOS touches() threw an error
Nicolas Ribot nicolas.ribot at gmail.com
Thu Aug 19 00:36:25 PDT 2010
On 19 August 2010 04:26, David Epstein <davideps at umich.edu> wrote:
> Hello,
> I have a postGIS polygon layer with about 320,000 rows. I am trying to
> return a table with object_number and the average area of the
> surrounding (touching) polygons. I am getting this error:
> NOTICE:  TopologyException: side location conflict 1.34593e+07 289017
> ERROR:  GEOS touches() threw an error!
> ********** Error **********
> SQL state: XX000
> I have tried to simplify the geometry many different times. Nothing
> seems to solve the problem. I can process the first 20,000 rows
> (object_number < 20000) but something is causing problems after that. I
> have pasted the script below, any suggestions would be welcomed!
> Thank you,
> -david
> SELECT p1.ogc_fid, avg(p2.shape_area)
> FROM parcels09_d3_v2_simplify as p1, parcels09_d3_v2_simplify as p2
> WHERE st_touches(p1.wkb_geometry, p2.wkb_geometry)
> GROUP BY p1.ogc_fid
> ORDER BY p1.ogc_fid
Are your geometries valid (st_isValid(), st_isValidReason()) ?
Nicolas
