[postgis-users] Raster to Polygon vector cell
Andreas Forø Tollefsen
andreasft at gmail.com
Mon Aug 23 06:33:55 PDT 2010
Hi
Thank you for your suggestions on reading material.
I will give it a try. Thanks.
Andreas
2010/8/23 Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> Andreas,
> This is one of the operation WKT Raster was made for. See the tutorial:
> http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01
> You will need to compile (if you are on Linux) or install (on Windows) the
> WKT Raster PostGIS extension. You import your shapefiles, you import your
> raster, then you do the proper query.
> Pierre
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Andreas Forø
> Tollefsen
> *Sent:* 21 août 2010 14:49
> *To:* postgis-users at postgis.refractions.net
> *Subject:* [postgis-users] Raster to Polygon vector cell
> Hi.
> I have been searching for a way to join raster values to polygons.
> In my case there is only one raster value within each polygon, and I would
> like this value to be joined into a column in the polygon table.
> The process would in other GIS programs probably look like this:
> Raster Data -> Point Features -> Spatial Join to Polygons (with raster
> value as new column for each polygon).
> Any ideas how one would formulate this?
> Thanks.
> Andreas
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100823/a8d97db8/attachment.html>
