[postgis-users] How to use accurate SRID ?
nguyen liem
liemnguyendl at gmail.com
Mon Aug 23 20:54:56 PDT 2010
Hi all,
I stored all my geometry in SRID 4326. I would like to calculate the
distance between 2 points in metter.
I see an example about ST_Distance_Sphere here:
http://postgis.refractions.net/docs/ST_Distance_Sphere.html
SELECT round(CAST(ST_Distance_Sphere(ST_Centroid(the_geom),
ST_GeomFromText('POINT(-118 38)',4326)) As numeric),2) As dist_meters,
round(CAST(ST_Distance(ST_Transform(ST_Centroid(the_geom),32611),
ST_Transform(ST_GeomFromText('POINT(-118 38)', 4326),32611)) As
numeric),2) As dist_utm11_meters,
round(CAST(ST_Distance(ST_Centroid(the_geom),
ST_GeomFromText('POINT(-118 38)', 4326)) As numeric),5) As
dist_degrees,
round(CAST(ST_Distance(ST_Transform(the_geom,32611),
numeric),2) As min_dist_line_point_meters
FROM
(SELECT ST_GeomFromText('LINESTRING(-118.584 38.374,-118.583 38.5)',
4326) As the_geom) as foo;
dist_meters | dist_utm11_meters | dist_degrees | min_dist_line_point_meters
70424.47 | *70438.00* | 0.72900 | 65871.18
SRID 32611: the distance is *70438.00* metters.
If i changed SRID from 32611 to 900913
70424.47 | *89738.89* | 0.72900 | 83857.70
SRID 32611: the distance is *89738.89* metters
I don't know what is the different between SRID 32611 and SRID 900913 ?
I should use 32611 or 900913 to calculate the distance in metter ?
Could i calculate distance by ST_Distance_Sphere for geometry with SRID 4326
Whats the different between ST_Distance_Sphere(SRID 4326), ST_Distance(SRID
32611), ST_Distance (SRID 900913) ?
Cheers.
*Liem Nguyen (DBA)
AXON ACTIVE VIETNAM*
*www.axonactive.vn***
10th Floor, Hai Au Building, 39B Truong Son, Ward 4, Tan Binh District, Ho
Chi Minh City, Vietnam
T +84 8 629 738 59, F +84 8 381 134 89, M +84 168 994 8897
*8897 +10° 48' 32.72", +106° 39' 51.58"*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100824/de62465f/attachment.html>
