[postgis-users] WKT Raster - geos version error while running rtpostgis.sql
Paragon Corporation
lr at pcorp.us
Thu Aug 26 23:25:23 PDT 2010
Tyler,
It just occurred to me that you can build GDAL with geos dependency and
since WKT Raster depends on GDAL, it might be your libgdal.so that is at
fault. Though I would expect eh error to be different.
Do you remember how you built libgdal? Since you had an older GEOS, maybe
you are just using an existing compiled libgdal compiled against an older
GEOS.
I'm not sure what happens in that case if libgdal is compiled with an older
GEOS than you compiled WKT Raster with.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tyler
Erickson
Sent: Tuesday, August 24, 2010 8:14 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] WKT Raster - geos version error while running
rtpostgis.sql
Yes, while building PostGIS I specified that it should use geos 3.2.2. Here
is the relevant output from the postgis ./configure step:
-------------- Dependencies --------------
GEOS config: /usr/local/geos/3.2.2/bin/geos-config
GEOS version: 3.2.2
PostgreSQL config: /usr/bin/pg_config
PostgreSQL version: PostgreSQL 8.4.4
PROJ4 version: 47
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.7.5
PostGIS debug level: 0
I also checked that when I request the postgis version from the template
database I created, it lists geos 3.2.2
psql -d $WKTRASTER_TEMPLATE -c "SELECT POSTGIS_FULL_VERSION()"
postgis_full_version
POSTGIS="1.5.1" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September 2009"
LIBXML="2.7.5" USE_STATS
As a work around, I included libgeos-3.2.0.so in my list of shared
libraries. Once this was done, the rtpostgis.sql script ran without an
error. But I still don't know why it requires geos 3.2.0.
- Tyler
Pierre Racine-2 wrote:
> Hi Tyler,
> Is this the same geos you are using when compiling PostGIS? WKT Raster
> is indirectly rependent on geos via PostGIS.
> Pierre
>>[mailto:postgis-users- bounces at postgis.refractions.net] On Behalf Of
>>Tyler Erickson
>>Sent: 20 août 2010 18:55
>>Subject: [postgis-users] WKT Raster - geos version error while running
rtpostgis.sql
>>I am trying to run WKT Raster's rtpostgis.sql against a database, but
>>am encountering in the following error:
>>psql:/usr/share/postgresql/8.4/contrib/rtpostgis.sql:32: ERROR: could
>>not load library "/usr/lib/postgresql/8.4/lib/rtpostgis.so":
libgeos-3.2.0.so:
>>cannot open shared object file: No such file or directory
>>I would have expected to see libgeos-3.2.2.so mentioned instead of
>>libgeos-3.2.0.so since I specified the GEOS version location during
>>the configure step.
>>~/src/wktraster$ ./configure
>>--with-postgis-sources=/home/terickson/src/postgis/postgis-1.5.1
>>--with-gdal=/usr/local/gdal/1.7.1/bin/gdal-config
>>--with-geos=/usr/local/geos/3.2.2/bin/geos-config
>>Other potentially relevant info:
>>OS: Ubuntu 9.10
>>PostGIS was built using GEOS 3.2.2
>>$ psql -d $WKTRASTER_TEMPLATE -c "SELECT POSTGIS_FULL_VERSION()"
>>September 2009" LIBXML="2.7.5" USE_STATS
>>(1 row)
>>I do have GEOS 3.2.0 installed on my system... but I was trying to use
>>the latest version.
>>Any idea why the WKT Raster script is trying to access GEOS 3.2.0
>>instead
of
>>the specified version 3.2.2?
>>- Tyler
>>View this message in context:
http://old.nabble.com/WKT-Raster---geos-version-error-while-running-
>>rtpostgis.sql-tp29496374p29496374.html
>>Sent from the PostGIS - User mailing list archive at Nabble.com.
>>_______________________________________________
>>postgis-users mailing list
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
http://old.nabble.com/WKT-Raster---geos-version-error-while-running-rtpostgi
s.sql-tp29496374p29521321.html
