[postgis-users] WKT Raster - geos version error while running rtpostgis.sql
Tyler Erickson tyler.erickson at mtu.edu
Fri Aug 27 05:11:14 PDT 2010
Regina,
Your guess was correct.  I did configure my gdal build (many months ago) and
included the --with-geos option.  I had forgotten about that.  Here is an
except from the configure output:
checking for geos-config... /usr/local/geos/3.2.0/bin/geos-config
checking for GEOS version >= 2.2.0... yes
checking for GEOSversion in -lgeos_c... yes
configure: Using C API from GEOS 3.2.0
Thanks for the insight!
- Tyler
Paragon Corporation-2 wrote:
> Tyler,
> It just occurred to me that you can build GDAL with geos dependency and
> since WKT Raster depends on GDAL, it might be your libgdal.so that is at
> fault. Though I would expect eh error to be different.
> Do you remember how you built libgdal?  Since you had an older GEOS, maybe
> you are just using an existing compiled libgdal compiled against an older
> GEOS.
> I'm not sure what happens in that case if libgdal is compiled with an
> older
> GEOS than you compiled WKT Raster with.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tyler
> Erickson
> Sent: Tuesday, August 24, 2010 8:14 AM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] WKT Raster - geos version error while running
> rtpostgis.sql
> Yes, while building PostGIS I specified that it should use geos 3.2.2.
> Here
> is the relevant output from the postgis ./configure step:
>  -------------- Dependencies --------------
>   GEOS config:          /usr/local/geos/3.2.2/bin/geos-config
>   GEOS version:         3.2.2
>   PostgreSQL config:    /usr/bin/pg_config
>   PostgreSQL version:   PostgreSQL 8.4.4
>   PROJ4 version:        47
>   Libxml2 config:       /usr/bin/xml2-config
>   Libxml2 version:      2.7.5
>   PostGIS debug level:  0
> I also checked that when I request the postgis version from the template
> database I created, it lists geos 3.2.2
> psql -d $WKTRASTER_TEMPLATE -c "SELECT POSTGIS_FULL_VERSION()"
>                                          postgis_full_version
> POSTGIS="1.5.1" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
> 2009"
> LIBXML="2.7.5" USE_STATS
> As a work around, I included libgeos-3.2.0.so in my list of shared
> libraries. Once this was done, the rtpostgis.sql script ran without an
> error.  But I still don't know why it requires geos 3.2.0.
> - Tyler
> Pierre Racine-2 wrote:
>> Hi Tyler,
>> Is this the same geos you are using when compiling PostGIS? WKT Raster
>> is indirectly rependent on geos via PostGIS.
>> Pierre
>>>[mailto:postgis-users- bounces at postgis.refractions.net] On Behalf Of
>>>Tyler Erickson
>>>Sent: 20 août 2010 18:55
>>>Subject: [postgis-users] WKT Raster - geos version error while running
> rtpostgis.sql
>>>I am trying to run WKT Raster's rtpostgis.sql against a database, but
>>>am encountering in the following error:
>>>psql:/usr/share/postgresql/8.4/contrib/rtpostgis.sql:32: ERROR:  could
>>>not load library "/usr/lib/postgresql/8.4/lib/rtpostgis.so":
> libgeos-3.2.0.so:
>>>cannot open shared object file: No such file or directory
>>>I would have expected to see libgeos-3.2.2.so mentioned instead of
>>>libgeos-3.2.0.so since I specified the GEOS version location during
>>>the configure step.
>>>~/src/wktraster$ ./configure
>>>--with-postgis-sources=/home/terickson/src/postgis/postgis-1.5.1
>>>--with-gdal=/usr/local/gdal/1.7.1/bin/gdal-config
>>>--with-geos=/usr/local/geos/3.2.2/bin/geos-config
>>>Other potentially relevant info:
>>>OS: Ubuntu 9.10
>>>PostGIS was built using GEOS 3.2.2
>>>$ psql -d $WKTRASTER_TEMPLATE -c "SELECT POSTGIS_FULL_VERSION()"
>>>September 2009" LIBXML="2.7.5" USE_STATS
>>>(1 row)
>>>I do have GEOS 3.2.0 installed on my system... but I was trying to use
>>>the latest version.
>>>Any idea why the WKT Raster script is trying to access GEOS 3.2.0
>>>instead
> of
>>>the specified version 3.2.2?
>>>- Tyler
>>>View this message in context:
> http://old.nabble.com/WKT-Raster---geos-version-error-while-running-
>>>rtpostgis.sql-tp29496374p29496374.html
>>>Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>_______________________________________________
>>>postgis-users mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> http://old.nabble.com/WKT-Raster---geos-version-error-while-running-rtpostgi
> s.sql-tp29496374p29521321.html
View this message in context: http://old.nabble.com/WKT-Raster---geos-version-error-while-running-rtpostgis.sql-tp29496374p29551944.html
