[postgis-users] ST_Difference and ST_Buffer queries
L Bogert-O'Brien
dlawbob at ncf.ca
Tue Aug 31 16:31:23 PDT 2010
When I used ST_Difference to clip one polygon from another where part
of the border of the polygon used for clipping is coincident with
part of the border of the one that is being clipped, I got a border
left which was not part of the main part of the polygon I wanted to keep.
A simple example:
I want to clip this:
| xxxxxxx
| xxxxxxx
| xxxxxxx
| xxxxxxx
| xxxxxxx
| xxxxxxx
With this:
| oooooooooooooo
| oooooooooooooo
| oooooooooooooo
And I get this result:
| xxxxxxx
| xxxxxxx
| xxxxxxx
| xxxxxxx
Instead of this desired result:
| xxxxxxx
| xxxxxxx
| xxxxxxx
Of course my borders are not this simple and it doesn't always keep
the whole coincident border opposite from the main part that I want
to keep, so I suppose even though they look coincident in QGIS, they
may not be exactly the same.
I did try buffering the clipping polygon with a small number
(0.0000002) and it seemed to get rid of most of the coincident
borders, but of course that way the clipping polygon is no longer its
original size. (Note that buffering with 0.0 on the results of the
ST_Difference had no effect. I thought this might help when reading
the documentation for ST_Intersection to get rid of the non-polygon
parts.) In addition, since I am using a lat/long Spatial Reference
System (NAD83: srid=4629), I guess I should transform it to something
like Lambert (eg. srid=3348) before doing the buffering, since there
would be quite a difference in the actual amount of buffering
depending on the latitude. Is that right?
Does anyone have an alternate suggestion that would get rid of these
unwanted borders, that would not involve changing the size of the
polygon used for clipping?
Thanks for your assistance.
Loretta
