[postgis-users] ST_Transform
Paul & Caroline Lewis
paulcaz80 at hotmail.com
Tue Aug 31 09:57:43 PDT 2010
Broad general query re this function and 3D. It doesn't mention support for projections in 3D space so I'm wondering 2 things. First, is a coordinate transformation in 3D space realistic, i.e. should the Z (altitude) value change between a projection from an ellipsoidal WGS84 projection into a cartesian local coordinate system. In my case I have alot of 3D point geometries in WGS84 yet any projections with ST_Transform into any local coordinate system does not alter the Z value. Thus to my second question, if the Z should change in a projection from WGS84 to a planar local coordinate system will ST_Transform be able to do it in the future and/or is there another method available now where I can achieve a projection in 3D space.
Thanks again in advance,
Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100831/0730de94/attachment.html>
