[postgis-users] Problem cleaning invalid geometries
L Bogert-OBrien dlawbob at ncf.ca
Mon Aug 30 22:26:15 PDT 2010
Thanks for all the suggestions.  I found that a big part of the problem
was that I had not set up indexes on the geometries.  Once I did that,
the functions worked much faster.
Regards,
Loretta
----- Original Message -----
Date: Friday, August 20, 2010 12:53 pm
Subject: Re: [postgis-users] Problem cleaning invalid geometries
> You could use ST_Dump() to split your multipolygon up and then run
> validity check/fix on the individual components...?
> P
> On Fri, Aug 20, 2010 at 9:44 AM, L Bogert-OBrien <dlawbob at ncf.ca>
> wrote:> Hi,
> > I am just wondering if there is a way to minimize the extent on
> which> the cleangeometry() function will act, or rewrite it so that
> it only
> > checks out the parts of the multipolygon near the problem area,
> rather> than having to wait for it to check the validity of all the
> pieces of
> > the multipolygon.  Then maybe I wouldn't have to wait days for it
> to return.
> > Any ideas?
> > Thanks,
> > Loretta
> >>I am not sure what you are trying to say with this, but the geometry
> >>that I am trying to clean is a multipolygon, not a collection.
> Yes, it
> >>is very big and has many points in the multipolygon, since it is the
> >>Baffin region, but it is not a collection.  ST_geometrytype returns
> >>multipolygon for it.
> > There are many possibly kind of invalidity.
> > If the invalidity is a self-intersect,
> > of course the ST_MakeValid() could split the polygon on the self-
> intersect and produce another multipolygon with one more part.
> > But if , for example, you multipolygon is invalid because it has
> a hole of type Linestring, or because it has two part that are
> touching along a line.
> > More probably the st_makevalid could be return a
> geometrycollection().>
> > Andrea Peri
> > qwerty àèìòùo
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
