[postgis-users] Determining clusters of points
Sébastien Lorion
sl at thestrangefactory.com
Wed Dec 8 15:49:17 PST 2010
Hello Kevin,
I am still testing/trying stuff .. One strange thing I saw is that if I set
the range to 40 instead of 80, then there are more clusters than there
should be, but at 50 it is ok. Using the buffer/merge method, it works
correctly. I did not investigate further into that.
Sébastien
On Wed, Dec 8, 2010 at 11:24, Kevin Neufeld <kneufeld.ca at gmail.com> wrote:
> On 12/8/2010 7:38 AM, Sébastien Lorion wrote:
>> The points are not static, they will potentially be in a different
>> position each time the query is run.
> Ah, I was going to ask about that. It might be possible to create a
> recursive query to maintain a very large point table as new records are
> added (add them to existing clusters and / or merge clusters), but according
> to my initial findings, there is no way a recursive query approach is going
> to be able to scale well enough for your million points, esp. if you need to
> be able to run such a query every 30 min. But I'd be curious to hear what
> your findings are as well.
> -- Kevin
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101208/2ddd39e4/attachment.html>
