[postgis-users] Determining clusters of points
Sébastien Lorion
sl at thestrangefactory.com
Wed Dec 8 15:58:07 PST 2010
Err, it is ok starting with 55, not 50, sorry. So to be clear, even tho the
points "interact" with a range of 40, they are not clustered together with
the function you sent.
Sébastien
On Wed, Dec 8, 2010 at 18:49, Sébastien Lorion <sl at thestrangefactory.com>wrote:
> Hello Kevin,
> I am still testing/trying stuff .. One strange thing I saw is that if I set
> the range to 40 instead of 80, then there are more clusters than there
> should be, but at 50 it is ok. Using the buffer/merge method, it works
> correctly. I did not investigate further into that.
> Sébastien
> On Wed, Dec 8, 2010 at 11:24, Kevin Neufeld <kneufeld.ca at gmail.com> wrote:
>> On 12/8/2010 7:38 AM, Sébastien Lorion wrote:
>>> The points are not static, they will potentially be in a different
>>> position each time the query is run.
>> Ah, I was going to ask about that. It might be possible to create a
>> recursive query to maintain a very large point table as new records are
>> added (add them to existing clusters and / or merge clusters), but according
>> to my initial findings, there is no way a recursive query approach is going
>> to be able to scale well enough for your million points, esp. if you need to
>> be able to run such a query every 30 min. But I'd be curious to hear what
>> your findings are as well.
>> -- Kevin
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101208/3866c280/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101208/3866c280/attachment.png>
