[postgis-users] Determining clusters of points
Sébastien Lorion
sl at thestrangefactory.com
Wed Dec 8 19:12:44 PST 2010
OK I get it, sorry I did not realize that.
Sébastien
On Wed, Dec 8, 2010 at 21:07, Kevin Neufeld <kneufeld.ca at gmail.com> wrote:
> On 12/8/2010 3:58 PM, Sébastien Lorion wrote:
>> ... So to be clear, even tho the points "interact" with a range of 40,
>> they are not clustered together with the function you sent.
> Um ... no. Sorry, there is miscommunication happening here.
> The recursive script I posted is checking if two points are within 80 units
> of each other. If you wanted to view the result as buffered areas, you
> would use a radius of 40, not 80.
> So, if you wanted to have clusters where points are within 40 units of each
> other, you would view this using a radius of 20.
> Make sense?
> -- Kevin
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101208/a23ccc6a/attachment.html>
