[postgis-users] Using CASE
Stephen Woodbridge woodbri at swoodbridge.com
Thu Feb 4 14:13:19 PST 2010
Bob,
You sub-select need to be enclosed in parens like:
  ... - (select case ...) ...
-Steve
Bob Pawley wrote:
> Hi
> I've been attempting to use CASE to establish the spatial point in the
> following expression.
> Update p_id.image
>  set the_geom =
>  (select st_translate(library.dgm_device.the_geom,
>  st_x (st_centroid(p_id.p_id.othe_geom))  -
>  st_x (st_centroid(library.dgm_device.ithe_geom)) ,
>  st_y (st_centroid(p_id.p_id.othe_geom)) - Select Case when
> p_id.devices.status = 'Pump #1'
>  and p_id.devices.devices_id = '3614'
>  then - 10000 -
>  st_y (st_centroid(library.dgm_device.the_geom)))
>  from p_id.p_id, library.dgm_device, p_id.processes, processes_count,
> p_id.devices
>  where library.dgm_device.description = 'In Line Pump'
>  and library.dgm_device.orientation = ta_orientation
>  and p_id.p_id.p_id_id = processes_count.p_id_id
>  and p_id.p_id.process_id = p_id.processes.process_id
>  and  p_id.processes.fluid_id = p_id.devices.fluid_id)
>  from p_id.devices
>  where p_id.image.fluid_id = p_id.devices.fluid_id
>  and p_id.image.text_ = 'Pump #1'
>  and p_id.image.device_id = '3614';
> I get - "ERROR:  syntax error at or near "Select"
> LINE 14:  st_y (st_centroid(p_id.p_id.othe_geom)"
> Any help would be appreciated.
> Bob
> postgis-users mailing list
