[postgis-users] [postgis-devel] Has anyone seen this before?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Feb 8 01:10:55 PST 2010
Paragon Corporation wrote:
> It should be noted that for this table
> the_geom is the first field in the table and addr_num_tlid comes right after
> and is a varchar
> I can select any integer or bigint field fine, but selecting any text or
> varchar field results in the
> ERROR:  invalid memory alloc request size 18446744073709551613
Yup, this is totally wrong. I suspect bad RAM and/or disk on the machine
in question.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
