[postgis-users] Character Primary Key
Marc Jansen
jansen at terrestris.de
Mon Feb 8 04:25:01 PST 2010
Hi Fabrice,
AFAIK this is still true for the latest QGIS versions. Anyway: I'd ask
again on the qgis-userlist if I were you:
http://lists.osgeo.org/mailman/listinfo/qgis-user
Regards,
Marc
F T wrote:
> Hello List
> QGis used to deal only with integer (INT4) primary keys (QGis 1.2
> PostgreSQL/Postgis 8.2).
> Do you know if it is still the case (QGis 1.4)?
> It is annoying for us that QGis can't use existing character primary
> key...
> We have to add an artificial integer primary key and transform the
> existing character primary key as a unique non null constraint.
> This change is ok if you only use QGis.
> But if the data are used by an other soft that was used do deal with
> this character primary key, this cause an interoperability problem.
> Does QGis still only deal with INT4 primary key?
> If the response is yes, is this expected to change in a further version?
> Thanks
> Fabrice
> postgis-users mailing list
