Thanks Mr. Steve. in consideration of your question: Is it noded? yes. Do all intersections occur only at the ends of you segments? yes all the times Or do you have line segments the cross other segments without a node at the intersection I fix this with arcmap I will do what you suggest. -Francisco Rada
