[postgis-users] Postgis 1.3.7 wit PostgreSQL 8.4. (64bit) on OpenSolaris
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Feb 24 01:43:51 PST 2010
Andreas Luka wrote:
> I compiled and installed geos-3.2.0 and proj-4.7.0 successfully with the
> following options
> CFLAGS="-m64" CPPFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64"
> FFLAGS="-m64" LDFLAGS="-L/usr/sfw/lib/amd64/" ./configure
> make, make install, make check are also okay, files are installed in
> /usr/local
> ls /usr/local -al
> drwxr-xr-x 2 root root 16 2010-02-24 00:43 .
> drwxr-xr-x 6 root other 6 2010-02-24 00:35 ..
> -rw-r--r-- 1 root root 296214 2010-02-24 00:35 libgeos_c.a
> -rwxr-xr-x+ 1 root root 1020 2010-02-24 00:35 libgeos_c.la
> lrwxrwxrwx 1 root root 18 2010-02-24 00:35 libgeos_c.so ->
> libgeos_c.so.1.6.0
> lrwxrwxrwx 1 root root 18 2010-02-24 00:35 libgeos_c.so.1 ->
> libgeos_c.so.1.6.0
> -rwxr-xr-x+ 1 root root 215312 2010-02-24 00:35 libgeos_c.so.1.6.0
> -rwxr-xr-x+ 1 root root 4777808 2010-02-24 00:35 libgeos-3.2.0.so
> -rw-r--r-- 1 root root 13625096 2010-02-24 00:35 libgeos.a
> -rwxr-xr-x+ 1 root root 988 2010-02-24 00:35 libgeos.la
> lrwxrwxrwx 1 root root 16 2010-02-24 00:35 libgeos.so ->
> libgeos-3.2.0.so
> -rw-r--r-- 1 root root 751590 2010-02-24 00:43 libproj.a
> -rwxr-xr-x+ 1 root root 841 2010-02-24 00:43 libproj.la
> lrwxrwxrwx 1 root root 16 2010-02-24 00:43 libproj.so ->
> libproj.so.0.6.6
> lrwxrwxrwx 1 root root 16 2010-02-24 00:43 libproj.so.0 ->
> libproj.so.0.6.6
> -rwxr-xr-x+ 1 root root 440672 2010-02-24 00:43 libproj.so.0.6.6
> I compiled postgis with the following options
> CC="gcc -m64" CXX="g++" FFLAGS="-m64" LDFLAGS="-L/usr/sfw/lib/amd64/"
> ./configure --with-pgsql='/usr/postgres/8.4/bin/amd64/pg_config'
> --with-geos='/usr/local/bin/geos-config' --with-proj='/usr/local'
> --with-proj-libdir='/usr/local/lib'
> make and make install are okay
> ls -al /usr/postgres/8.4/lib/amd64/liblwgeo*
> lrwxrwxrwx 1 root root 16 2010-02-24 00:45
> /usr/postgres/8.4/lib/amd64/liblwgeom.so -> liblwgeom.so.1.3
> /usr/postgres/8.4/lib/amd64/liblwgeom.so.1 -> liblwgeom.so.1.3
> -rwxr-xr-x 1 root root 980520 2010-02-24 00:45
> /usr/postgres/8.4/lib/amd64/liblwgeom.so.1.3
> echo $LD_LIBRARY_PATH
> /usr/local/lib
> seems okay, restart of the database
> but I still getting the following error when I run the sql query for
> lwpostgis.sql:
> HINWEIS: Typ »histogram2d« ist noch nicht definiert
> DETAIL: Hüllentypdefinition wird erzeugt.
> FEHLER: konnte Bibliothek »/usr/postgres/8.4/lib/amd64/liblwgeom.so«
> nicht laden: ld.so.1: postgres: fatal: libgeos_c.so.1: open failed: No
> such file or directory
> ********** Fehler **********
> SQL Status:58P01
> Any suggestion?
How are you starting PostgreSQL? Bear in mind you need to make sure that
LD_LIBRARY_PATH is being set for the postgres user as you start the
database, and not just the user you are logged in as. You may need to
alter the /etc/init.d/postgresql script in order to do this.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
