[postgis-users] Read file encoding from from shape file
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Fri Feb 26 05:55:56 PST 2010
Hi
Looking into the sources of shp2pgsql, [0], it seems that the loader
assumes that the encoding of the dbf file is "WINDOWS-1252", if not
specified differently by the -W command line option.
From [1], shape files carry some information about their encoding,
either in the dbf file header at byte position 29, [2], or in a separate
file with extension CPG.
Would it make sense to change the default behaviour of shp2pgsql into:
1) try to get file encoding from dbf file or cpg file
2) if 1) fails, take WINDOWS-1252 as default
3) if -W is given, take this option
And then, is the information about the encoding set by pgsql2shp? It
would be smooth, if shapes generated by pgsql2shp could be imported by
shp2pgsql without specifying any encoding during import ("just works").
Regards,
Peter
[0] http://trac.osgeo.org/postgis/browser/trunk/loader/
[1]
http://support.esri.com/index.cfm?fa=knowledgebase.techArticles.articleShow&d=21106
[2] http://www.dbase.com/knowledgebase/int/db7_file_fmt.htm
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax : +39 0473 069902
www : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
