[postgis-users] Import geometry problems
Tim Semmelhaack
semmelhaack at gmail.com
Sat Feb 27 10:07:34 PST 2010
Hello,
I created a sql-file with shp2pgsql from a ArcGIS-Shapefile with linestrings.
Some datasets compromises long strings in the geometry field (> 5000 characters)
After the import the geometry is blank, others fields with a shorter
string are filled.
I attached the sql-file, (the geometry looks strange but these are bus
routes in the rural area !).
The first dataset doesn't work, the second one does.
I've created the files with windows but also with linux - same result.
Any explanations, suggestions?
Tim
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100227/5bd8050b/attachment.obj>
