[postgis-users] pgsql2shp usage
Chris Hermansen chris.hermansen at timberline.ca
Sat Jan 9 12:09:46 PST 2010
Anisha, why are you converting to shape file?
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.840.4625
Timberline Natural Resource Group · www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
-----Original Message-----
From: Anisha Kaul <anisha.kaul at hitechroboticsystemz.com>
Date: Sat, 9 Jan 2010 18:06:34
To: <postgis-users at postgis.refractions.net>
Subject: [postgis-users] pgsql2shp usage
Hello to all,
I hope this is the right mailing lists w.r.t pgsql2shp.
I downloaded an OSM map file namely "india.osm.bz2".
I transported it in PostgreSQL database "gis" with the command :
./osm2pgsql -m -d gis india.osm.bz2
The above command resulted in the creation of the following tables filled with data in database "gis"
gis=# \d
                 List of relations
 Schema |        Name        |   Type   |  Owner
 public | geometry_columns   | table    | anisha
 public | planet_osm_line    | table    | anisha
 public | planet_osm_point   | table    | anisha
 public | planet_osm_polygon | table    | anisha
 public | planet_osm_roads   | table    | anisha
 public | polygon_oid_seq    | sequence | postgres
 public | spatial_ref_sys    | table    | anisha
Now to convert the map data of one of the above tables in a shape file, I issued the following command:
pgsql2shp -f myfile gis planet_osm_line
Output:
Initializing... Warning, field addr:housenumber renamed to ADDR:HOUSE
Warning, field addr:interpolation renamed to ADDR:INTER
Warning, field admin_level renamed to ADMIN_LEVE
Warning, field construction renamed to CONSTRUCTI
Warning, field power_source renamed to POWER_SOUR
Done (postgis major version: 1).
Output shape: PolyLine
Dumping:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
[126149 rows].
Questions :
_______________________________________________________________________________________
Are these the right steps to load an OSM file in postgres ?
How should I verify that the shape file resultant of the above command is a valid and uncorrupted one ?
I am worried because the projection file namely "myfile.prj" contains the following !
PROJCS["WGS84 / Simple Mercator",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS_1984", 6378137.0,
298.257223563]],PRIMEM["Greenwich", 0.0],UNIT["degree", 0.017453292519943295],AXIS["Longitude",
EAST],AXIS["Latitude", NORTH]],PROJECTION["Mercator_1SP_Google"],PARAMETER["latitude_of_origin",
0.0],PARAMETER["central_meridian", 0.0],PARAMETER["scale_factor", 1.0],PARAMETER["false_easting",
0.0],PARAMETER["false_northing", 0.0],UNIT["m", 1.0],AXIS["x", EAST],AXIS["y", NORTH],AUTHORITY["EPSG","900913"]]
The latitude/longitude values don't seem to be of India !!!!
Kindly help !!
Thanking you in anticipation,
Regards,
Anisha Kaul
Hi-Tech Gears Limited, Gurgaon, India
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
