[postgis-users] pgsql2shp usage
Paragon Corporation
lr at pcorp.us
Sat Jan 9 12:42:24 PST 2010
Anish,
Question 1
The warnings. That's because esri shape file format is dbf which only
allows 10 characters for a field name. So the warning is telling you its
truncating the names so they are within 10 characters. Your field names in
the dbf will be slightly different is all
Question 2
Never worked with osm data, but since I created the .prj generator in
pgsql2shp, I can tell you it reads the srid of the geometry and looks up the
srtext in spatial ref and outputs that to the .prj file.
I suspect osm data is in Mercator not long lat. If you want your output to
be in long lat, you need to transform and use an sql statement
pgsql2shp -f "/path/to/filename" -h myserver -u apguser -P apgpassword
mygisdb
"SELECT field1 AS hs_num, field2...., ST_Transform(the_geom,4326) As
the_geom FROM planet_osm_line"
Or you can create a view with a transformed geometry.
Using an SQL statement or a view will also allow you to control how the
fields are renamed since you can alias them as names less than 10
characters,
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Anisha
Kaul
Sent: Saturday, January 09, 2010 7:37 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] pgsql2shp usage
Hello to all,
I hope this is the right mailing lists w.r.t pgsql2shp.
I downloaded an OSM map file namely "india.osm.bz2".
I transported it in PostgreSQL database "gis" with the command :
./osm2pgsql -m -d gis india.osm.bz2
The above command resulted in the creation of the following tables filled
with data in database "gis"
gis=# \d
List of relations
Schema | Name | Type | Owner
public | geometry_columns | table | anisha
public | planet_osm_line | table | anisha
public | planet_osm_point | table | anisha
public | planet_osm_polygon | table | anisha
public | planet_osm_roads | table | anisha
public | polygon_oid_seq | sequence | postgres
public | spatial_ref_sys | table | anisha
Now to convert the map data of one of the above tables in a shape file, I
issued the following command:
pgsql2shp -f myfile gis planet_osm_line
Output:
Initializing... Warning, field addr:housenumber renamed to ADDR:HOUSE
Warning, field addr:interpolation renamed to ADDR:INTER Warning, field
admin_level renamed to ADMIN_LEVE Warning, field construction renamed to
CONSTRUCTI Warning, field power_source renamed to POWER_SOUR Done (postgis
major version: 1).
Output shape: PolyLine
Dumping:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
XX
[126149 rows].
Questions :
____________________________________________________________________________
___________
Are these the right steps to load an OSM file in postgres ?
How should I verify that the shape file resultant of the above command is a
valid and uncorrupted one ?
___________
I am worried because the projection file namely "myfile.prj" contains the
following !
PROJCS["WGS84 / Simple Mercator",GEOGCS["WGS
84",DATUM["WGS_1984",SPHEROID["WGS_1984", 6378137.0,
298.257223563]],PRIMEM["Greenwich", 0.0],UNIT["degree",
0.017453292519943295],AXIS["Longitude",
EAST],AXIS["Latitude",
NORTH]],PROJECTION["Mercator_1SP_Google"],PARAMETER["latitude_of_origin",
0.0],PARAMETER["central_meridian", 0.0],PARAMETER["scale_factor",
1.0],PARAMETER["false_easting", 0.0],PARAMETER["false_northing",
0.0],UNIT["m", 1.0],AXIS["x", EAST],AXIS["y",
NORTH],AUTHORITY["EPSG","900913"]]
The latitude/longitude values don't seem to be of India !!!!
Kindly help !!
Thanking you in anticipation,
Regards,
Anisha Kaul
Hi-Tech Gears Limited, Gurgaon, India
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
