[postgis-users] Expanding a polygon
Kevin Neufeld
kneufeld at refractions.net
Mon Jan 11 12:29:51 PST 2010
It sounds like you'd like to apply an affine transformation (ST_Affine) to your geometry.
Two simple wrappers may help you:
ST_Scale will expand/scale a polygon by a specified value in x and y.
ST_Translate will translate the geometry if you wanted to scale at the midpoint of the geometry.
SELECT
ST_AsText(
ST_Translate(
ST_Scale(geom, 3, 2),
-3 * (ST_Xmin(geom)+ST_XMax(geom))/2 + ((ST_Xmin(geom)+ST_XMax(geom))/2),
-2 * (ST_Ymin(geom)+ST_YMax(geom))/2 + ((ST_Ymin(geom)+ST_YMax(geom))/2))
FROM
(SELECT 'POLYGON (( 2 5, 2 6, 3 6, 3 5, 2 5 ))'::geometry AS geom) a;
st_astext
POLYGON((1 4.5,1 6.5,4 6.5,4 4.5,1 4.5))
(1 row)
-- Or use ST_Affine directly:
SELECT
ST_AsText(
ST_Affine(
geom, 3, 0, 0, 2,
FROM
st_astext
(1 row)
Ideally, it looks like there should an optional parameter to ST_Scale that would allow a user to scale about the
midpoint or lower left directly. I'll add this as a wish list item.
Cheers,
Kevin
Yurka wrote:
> I'm wondering if such thing exists.
> I have a polygon that i need to expand by x for each coordinate
> equivalent would be a function ST_Expand(), but ST_Expand expands the
> bounding box not the polygon itself.
> maybe someone has a workaround?
> thanks in advance.
