[postgis-users] WKT Raster
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Tue Jan 12 12:33:25 PST 2010
HI,
I just installed wktraster_pg83 using this link
http://www.postgis.org/download/windows/pg83/experimental/wktraster/
I guess the next step is to use gdal2wktraster.py to load an image in
postgis.
I don't know the syntax to use so I tried this command
C:\Python\python.exe gdal2wktraster.py --help
I got this error
  File "gdal2wktraster.py", line 32, in <module>
    from osgeo import gdal
  File "C:\Python\lib\site-packages\osgeo\gdal.py", line 7, in <module>
    import _gdal
ImportError: DLL load failed: Le module spÚcifiÚ est introuvable.
What is it missing?
Also, any doc on how to use gdal2wktraster.py?
thanks
steve
"Paragon Corporation" <lr at pcorp.us>@postgis.refractions.net
Envoyé par : postgis-users-bounces at postgis.refractions.net
07/12/2009 10:37 PM
Veuillez répondre à
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
A
"'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
cc
Objet
Re: [postgis-users] Suggestion Needed
FWIW for Windows users, we do have fairly recent compiled WKT Raster as of
December 4th, 2009.  Give it a try.  I haven't had chance to try WKT
Raster yet, but hopefully this will encourage people to give it a try.
http://www.postgis.org/download/windows/experimental.php
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pierre
Racine
Sent: Monday, December 07, 2009 3:27 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Suggestion Needed
Mukesh,
Sorry for the late answer. You can give a try to WKT Raster. You will have
to compile it though. Loading Geotiff should then be straightforward using
gdal2wktraster.py.
Pierre
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of mukesh
karanwal
Sent: 25 novembre 2009 06:30
Hi..
thanks for the reply.
i did it but still it is showing the same error!
I actually want to store a Geotiff file in the databse, could you please
tell, is there any other way to do this? or where am i doing mistake, if
any?
Thanks
--- On Tue, 11/24/09, Luigi Castro Cardeles <luigi.cardeles at gmail.com>
wrote:
From: Luigi Castro Cardeles <luigi.cardeles at gmail.com>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Tuesday, November 24, 2009, 10:17 PM
to "bypass" the password, you can make the .pgpass file and fill that with
your connection params (hostname:port:database_name:user:password).
If you are using windows, the path is: C:\Users\<your user
name>\AppData\Roaming\postgresql\.pgpass
best regards
2009/11/24 mukesh karanwal <mukesh_karanwal at yahoo.com>
Hey Everyone,
I am trying to store raster data in Postgis/PostgrSQL using "
geotiff2pgrstaer.exe". but evertime i get an error that "when making
connection to PostgreSQL: fe_sendauth: no password supplied", though i am
supplying all the information.
The command i am giving is like:
C:\..> geotiff2pgraster -h localhost -p 5432 -d postgis -U postgres -P
<mypassword> data.tif(strored at this location only) tablename
Kindly tell the remedy for the above problem and also is there any other
way out to store raster data until now?
Thanks in anticipation
With Regards,
Mukesh
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100112/89a47a5c/attachment.html>
