[postgis-users] Installing PostGIS-1.4.1
Paragon Corporation
lr at pcorp.us
Thu Jan 14 12:36:25 PST 2010
Torsten,
I think your postgis install is fine. You are missing the srid 900913 in
your spatial_ref_sys table.
Just need to add it. That one is not normally installed.
check http://spatialreference.org
to get the insert statement to use (well I think it might be there) or
someone knows here off-hand what the insert statement should be.
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Torsten
Mohr
Sent: Thursday, January 14, 2010 3:24 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Installing PostGIS-1.4.1
Hello,
i downloaded and installed the prerequisites for PostGIS, started postgresql
(8.4). I work on linux, OpenSuSE 11.2.
After starting PostgreSQL i created a database "gis":
createdb -E UTF8 -O tmohr gis
createlang plpgsql gis
Then i tried to prepare that DB further:
pgsql -f postgis/postgis.sql -d gis
This leads to the warnings that i attached below.
I'm not sure now if everything went ok or (if not) what i need to change.
The following import of the planet.osm fails:
postgres at schleim:/local/ftp/osm> osm2pgsql -s planet-090408.osm.bz2
osm2pgsql SVN version 0.69-19517
Using projection SRS 900913 (Spherical Mercator) Setting up table:
planet_osm_point
HINWEIS: Tabelle »planet_osm_point« existiert nicht, wird übersprungen
HINWEIS: Tabelle »planet_osm_point_tmp« existiert nicht, wird übersprungen
SELECT AddGeometryColumn('planet_osm_point', 'way', 900913, 'POINT', 2 );
failed: FEHLER: AddGeometryColumns() - invalid SRID
CONTEXT: SQL statement "SELECT AddGeometryColumn('','', $1 , $2 , $3 , $4 ,
$5 )"
PL/pgSQL-Funktion »addgeometrycolumn« Zeile 5 bei SQL-Anweisung
Error occurred, cleaning up
I found several pieces of descriptions of how to set up a posgis server, not
sure if i did all necessary steps.
If anybody could give me a hint on what to change, that would be great.
Thanks for any hints,
Torsten.
---------Warnings:
BEGIN
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:56: HINWEIS: Typ »spheroid« ist
noch nicht definiert
DETAIL: Hüllentypdefinition wird erzeugt.
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:62: HINWEIS: Rückgabetyp
spheroid ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:68: HINWEIS: Argumenttyp
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:74: HINWEIS: Argumenttyp
CREATE FUNCTION
CREATE TYPE
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:91: HINWEIS: Typ »geometry« ist
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:97: HINWEIS: Rückgabetyp
geometry ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:103: HINWEIS: Argumenttyp
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:109: HINWEIS: Argumenttyp
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:127: HINWEIS: Rückgabetyp
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:133: HINWEIS: Rückgabetyp
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:139: HINWEIS: Argumenttyp
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:145: HINWEIS: Argumenttyp
CREATE FUNCTION
CREATE TYPE
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:326: HINWEIS: Typ »box3d« ist
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:332: HINWEIS: Argumenttyp box3d
ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:338: HINWEIS: Rückgabetyp box3d
ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:344: HINWEIS: Argumenttyp box3d
ist nur eine Hülle
CREATE FUNCTION
CREATE TYPE
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:359: HINWEIS: Typ
»box3d_extent« ist noch nicht definiert
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:364: HINWEIS: Argumenttyp
box3d_extent ist nur eine Hülle
CREATE FUNCTION
CREATE TYPE
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:382: HINWEIS: Typ »box2d« ist
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:470: HINWEIS: Typ »chip« ist
noch
nicht definiert
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:476: HINWEIS: Rückgabetyp chip
ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:482: HINWEIS: Argumenttyp chip
ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:488: HINWEIS: Argumenttyp chip
ist nur eine Hülle
CREATE FUNCTION
CREATE TYPE
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:506: HINWEIS: Rückgabetyp box2d
ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:512: HINWEIS: Rückgabetyp box2d
ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:518: HINWEIS: Argumenttyp box2d
ist nur eine Hülle
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:524: HINWEIS: Argumenttyp box2d
ist nur eine Hülle
CREATE FUNCTION
CREATE TYPE
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:2243: HINWEIS: CREATE TABLE /
PRIMARY KEY erstellt implizit einen Index »spatial_ref_sys_pkey« für Tabelle
»spatial_ref_sys«
CREATE TABLE
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:2261: HINWEIS: CREATE TABLE /
PRIMARY KEY erstellt implizit einen Index »geometry_columns_pk« für Tabelle
»geometry_columns«
CREATE TABLE
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE AGGREGATE
CREATE AGGREGATE
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:4085: HINWEIS: Typ »pgis_abs«
ist
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:4090: HINWEIS: Argumenttyp
pgis_abs ist nur eine Hülle
CREATE FUNCTION
CREATE TYPE
CREATE FUNCTION
CREATE FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6942: HINWEIS: Funktion
asgml(geometry,pg_catalog.int4,pg_catalog.int4) existiert nicht, wird
übersprungen DROP FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6943: HINWEIS: Funktion
asukml(geometry,pg_catalog.int4,pg_catalog.int4) existiert nicht, wird
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6944: HINWEIS: Funktion
asukml(geometry,pg_catalog.int4) existiert nicht, wird übersprungen DROP
FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6945: HINWEIS: Funktion
asukml(geometry) existiert nicht, wird übersprungen DROP FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6946: HINWEIS: Funktion
create_histogram2d(box2d,pg_catalog.int4) existiert nicht, wird übersprungen
DROP FUNCTION DROP FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6948: HINWEIS: Funktion
jtsnoop(geometry) existiert nicht, wird übersprungen DROP FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6949: HINWEIS: Funktion
postgis_jts_version() existiert nicht, wird übersprungen DROP FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6950: HINWEIS: Funktion
st_pointn(geometry) existiert nicht, wird übersprungen DROP FUNCTION
psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6951: HINWEIS: Funktion
st_create_histogram2d(box2d,pg_catalog.int4) existiert nicht, wird
übersprungen DROP FUNCTION COMMIT
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
