[postgis-users] Installing PostGIS-1.4.1
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jan 14 12:45:11 PST 2010
Leo,
Since 900913 is in such common use why don't we install it as part of
the postgis install or at least include an extra file that can be used
to optionally install it.
-Steve W
Paragon Corporation wrote:
> Torsten,
> I think your postgis install is fine. You are missing the srid 900913 in
> your spatial_ref_sys table.
> Just need to add it. That one is not normally installed.
> check http://spatialreference.org
> to get the insert statement to use (well I think it might be there) or
> someone knows here off-hand what the insert statement should be.
> Leo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Torsten
> Mohr
> Sent: Thursday, January 14, 2010 3:24 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Installing PostGIS-1.4.1
> Hello,
> i downloaded and installed the prerequisites for PostGIS, started postgresql
> (8.4). I work on linux, OpenSuSE 11.2.
> After starting PostgreSQL i created a database "gis":
> createdb -E UTF8 -O tmohr gis
> createlang plpgsql gis
> Then i tried to prepare that DB further:
> pgsql -f postgis/postgis.sql -d gis
> This leads to the warnings that i attached below.
> I'm not sure now if everything went ok or (if not) what i need to change.
> The following import of the planet.osm fails:
> postgres at schleim:/local/ftp/osm> osm2pgsql -s planet-090408.osm.bz2
> osm2pgsql SVN version 0.69-19517
> Using projection SRS 900913 (Spherical Mercator) Setting up table:
> planet_osm_point
> HINWEIS: Tabelle »planet_osm_point« existiert nicht, wird übersprungen
> HINWEIS: Tabelle »planet_osm_point_tmp« existiert nicht, wird übersprungen
> SELECT AddGeometryColumn('planet_osm_point', 'way', 900913, 'POINT', 2 );
> failed: FEHLER: AddGeometryColumns() - invalid SRID
> CONTEXT: SQL statement "SELECT AddGeometryColumn('','', $1 , $2 , $3 , $4 ,
> $5 )"
> PL/pgSQL-Funktion »addgeometrycolumn« Zeile 5 bei SQL-Anweisung
> Error occurred, cleaning up
> I found several pieces of descriptions of how to set up a posgis server, not
> sure if i did all necessary steps.
> If anybody could give me a hint on what to change, that would be great.
> Thanks for any hints,
> Torsten.
> ---------Warnings:
> BEGIN
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:56: HINWEIS: Typ »spheroid« ist
> noch nicht definiert
> DETAIL: Hüllentypdefinition wird erzeugt.
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:62: HINWEIS: Rückgabetyp
> spheroid ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:68: HINWEIS: Argumenttyp
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:74: HINWEIS: Argumenttyp
> CREATE FUNCTION
> CREATE TYPE
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:91: HINWEIS: Typ »geometry« ist
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:97: HINWEIS: Rückgabetyp
> geometry ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:103: HINWEIS: Argumenttyp
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:109: HINWEIS: Argumenttyp
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:127: HINWEIS: Rückgabetyp
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:133: HINWEIS: Rückgabetyp
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:139: HINWEIS: Argumenttyp
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:145: HINWEIS: Argumenttyp
> CREATE FUNCTION
> CREATE TYPE
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:326: HINWEIS: Typ »box3d« ist
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:332: HINWEIS: Argumenttyp box3d
> ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:338: HINWEIS: Rückgabetyp box3d
> ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:344: HINWEIS: Argumenttyp box3d
> ist nur eine Hülle
> CREATE FUNCTION
> CREATE TYPE
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:359: HINWEIS: Typ
> »box3d_extent« ist noch nicht definiert
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:364: HINWEIS: Argumenttyp
> box3d_extent ist nur eine Hülle
> CREATE FUNCTION
> CREATE TYPE
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:382: HINWEIS: Typ »box2d« ist
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:470: HINWEIS: Typ »chip« ist
> noch
> nicht definiert
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:476: HINWEIS: Rückgabetyp chip
> ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:482: HINWEIS: Argumenttyp chip
> ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:488: HINWEIS: Argumenttyp chip
> ist nur eine Hülle
> CREATE FUNCTION
> CREATE TYPE
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:506: HINWEIS: Rückgabetyp box2d
> ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:512: HINWEIS: Rückgabetyp box2d
> ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:518: HINWEIS: Argumenttyp box2d
> ist nur eine Hülle
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:524: HINWEIS: Argumenttyp box2d
> ist nur eine Hülle
> CREATE FUNCTION
> CREATE TYPE
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:2243: HINWEIS: CREATE TABLE /
> PRIMARY KEY erstellt implizit einen Index »spatial_ref_sys_pkey« für Tabelle
> »spatial_ref_sys«
> CREATE TABLE
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:2261: HINWEIS: CREATE TABLE /
> PRIMARY KEY erstellt implizit einen Index »geometry_columns_pk« für Tabelle
> »geometry_columns«
> CREATE TABLE
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE AGGREGATE
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:4085: HINWEIS: Typ »pgis_abs«
> ist
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:4090: HINWEIS: Argumenttyp
> pgis_abs ist nur eine Hülle
> CREATE FUNCTION
> CREATE TYPE
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6942: HINWEIS: Funktion
> asgml(geometry,pg_catalog.int4,pg_catalog.int4) existiert nicht, wird
> übersprungen DROP FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6943: HINWEIS: Funktion
> asukml(geometry,pg_catalog.int4,pg_catalog.int4) existiert nicht, wird
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6944: HINWEIS: Funktion
> asukml(geometry,pg_catalog.int4) existiert nicht, wird übersprungen DROP
> FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6945: HINWEIS: Funktion
> asukml(geometry) existiert nicht, wird übersprungen DROP FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6946: HINWEIS: Funktion
> create_histogram2d(box2d,pg_catalog.int4) existiert nicht, wird übersprungen
> DROP FUNCTION DROP FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6948: HINWEIS: Funktion
> jtsnoop(geometry) existiert nicht, wird übersprungen DROP FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6949: HINWEIS: Funktion
> postgis_jts_version() existiert nicht, wird übersprungen DROP FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6950: HINWEIS: Funktion
> st_pointn(geometry) existiert nicht, wird übersprungen DROP FUNCTION
> psql:/tmp/postgis-1.4.1/postgis/postgis.sql:6951: HINWEIS: Funktion
> st_create_histogram2d(box2d,pg_catalog.int4) existiert nicht, wird
> übersprungen DROP FUNCTION COMMIT
> postgis-users mailing list
