[postgis-users] Postgis installation
Oscar Zamudio cmntlk at gmail.com
Fri Jan 15 10:55:25 PST 2010
Thanks to all.
Of course the template_postgis database was created when I installed
PostGIS. And I used template_postgis to create my own  PosGIS enabled
database. I was not aware that there (postgis_template) I can find the
tables I was looking for....
By the way my spatial application is working like a charm so everything it's
ok.
Thanks again and regards,
Oscar
On Wed, Jan 13, 2010 at 8:28 PM, Paragon Corporation <lr at pcorp.us> wrote:
>  Oscar,
> The template database Nicklas is refering to is called template_postgis.
> That always gets installed with the windows installer.  You can't uncheck
> it so no need to go back to install to get it.  The test database postgis
> that gets created is just a sample database.  I personally uncheck that
> setting.
> To create a new postgis database, you use the template_postgis as the
> template. (instead of the default template1 )
> Its all outlined here
> http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_tut01
> (though note this one is for PostGIS 1.4)
> There is no such table called SPATIAL_GEOMETRY_COLUMNS .
> The tables are
> *geometry_columns* and *spatial_ref_sys*
> If you don't see those in your database or the below function doesn't work,
> then you do not have postgis installed in your database
> SELECT postgis_full_version();
> As Nicklas said better to go with PostGIS 1.4.1, but if you are using
> postgis 1.3.6, then the file is called lwpostgis.sql (instead of
> postgis.sql  (for 1.4 and upcoming 1.5))
> Hope that clarifies things.
> Thanks,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Nicklas Avén
> *Sent:* Wednesday, January 13, 2010 9:08 AM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Postgis installation
>  How do you mean it is working well?
> If you have all the spatial functionality working you most likely have :
> geometry_columns
> and
> spatial_ref _sys table
> in your public schema.
> But as I understood you, you have installed PostGIS with stackbuilder but
> without creating the template-database. Then all nessecary dll-files and
> sql-scrips is installed, but the database is not spatially enabled. And that
> can be done as I described in last mail. That have to be done for each new
> database that you want to use spatial functionality in. The difference if
> you had installed the template database is that then you could have
> spatially enabled a new database by using db postgis as template.
> So
> Do you have a functional database with spatial functionality eg
> st_distance, st_union and so on? or have you "only" installed postgis in the
> server, yet.
> /Nicklas
> 2010-01-13 Oscar Zamudio wrote:
> Thanks Nicklas,>
> Maybe I did not expressed my questions very well. I already have a database
> with PostGIS enabled and I am working well with it. I installed PostGIS
> 1.3.6 in PostgreSQL as I mentioned using the App. Stack Builder.
> My problem is that now I want to check some PostGIS features as Reference
> systems because I need to measure distances etc.. As I'm reading the
> manuals, I learned about the existence of a SPATIAL_GEOMETRY_COLUMNS table
> (or example) that I didn't find in my installation nor in my customer
> installation. I used to see in another installation a database with the name
> "postgis" so I thought that maybe in that database (that I guess is a master
> database for PostGIS extension) I would find the tables that mention hte
> manuals.
> As I made a mistake in the original installation of PostGIS (didn't check
> the creation of "postgis" database) I want to reinstall it and this time
> check that option. How can I make this reinstallation and more important:
> can I do this without affecting my own PostGIS enabled database I already
> created in PosgreSQL?
> I certainly cannot update now to the last version of PostgreSQL and PostGIS
> because my customer use this configuration and I don't want to push them now
> to make these changes.
> Regards
> On Wed, Jan 13, 2010 at 10:33 AM, Nicklas Avén <nicklas.aven at jordogskog.no>
> wrote:
> Hallo Oscar >
> You can spatially enable any database by loading and running
> lwpostgis.sql
> and
> spatial_ref_sys.sql
> for instance in pgAdmin
> I think that's the right name of the files for your version and you can
> find them in :
> C:\Program files\PostgreSQL\8.3\share\contrib
> or something corresponing on your system.
> Probably you will have to remove the lines with "vacuum" in the
> spatial_ref_sys.sql before running. That issue shoud be fixed in upcoming
> PostGIS 1.5
> But if you have the possibility you probably want to upgrade both database
> and postgis. Latest stable now is
> PostgreSQL 8.4.2 and PostGIS 1.4. Hopefully in a couple of weeks PostGIS
> 1.5 will be released.
> Hope that helps
> Nicklas>
> > Hi everybody. I'm a newbie and trying to use PostGIS with PostgreSQL in
> Windows. I installed PostgreSQL 8.3 and also PostGIS 1.3.6 using the
> Application Stack Builder. Spatial queries are working fine but I have some
> doubts about the PostGIS configuration. Where can I find the SPATIAL_REF_SYS
> Table for example, or the GEOMETRY_COLUMNS table? At the time I was
> installing the PostGIS extension I didn't check the creation of a postgis
> database. I guess postgis database contains the tables that I'm looking for.
> Am I wrong? >
> I was thinking in reinstall the PostGIS 1.3.6 and create the postgis
> database but I don't know how, as the Application Stack Builder doesn't
> allow me to do that. Can anybody help me? Thanks in advance
> >_______________________________________________
> > postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100115/52d66869/attachment.html>
