[postgis-users] Questions about using SRID not -1
Chris Hermansen chris.hermansen at timberline.ca
Wed Jan 20 16:55:41 PST 2010
Have you tried UpdateGeometrySRID()
http://www.postgis.org/documentation/manual-1.4/UpdateGeometrySRID.html
Oscar Zamudio wrote:
> Hi,
> I tried:
> UPDATE  mypoints SET the_geom_4326=transform(the_geom,4326)
> But again I got:
> ERROR:  Input geometry has unknown (-1) SRID
> It seems that once the data is without explicit SRID, they cannot
> be processed later for asigning a proper SRID.
> It is strange at first sight....but I'm a newbie so I don't know much
> about this.
> Regards,
>             Oscar
> On Tue, Jan 19, 2010 at 6:27 AM, ibrahim saricicek
> <ibrahimsaricicek at gmail.com <mailto:ibrahimsaricicek at gmail.com>> wrote:
>     Hi,
>     Your table include objects, more than one projection.. So if there
>     is any object in different projection you can't set your table
>     projection to 4326...
>     can you try this!!
>     Create a new geometry column "the_geom_4326"
>     then run this
>     UPDATE  table_name SET the_geom_4326=transform(the_geom,4326),
>     then use ST_SetSRID for the new column...
>     REgards,
>     ibo...
>     On Mon, Jan 18, 2010 at 7:23 PM, Oscar Zamudio <cmntlk at gmail.com
>     <mailto:cmntlk at gmail.com>> wrote:
>         Hi everybody.
>         I had no success with any of the recipes received here.
>         Could it be that a table with data loaded without SRID
>         explicit value has no chance of being updated later to the
>         right one?
>         Regards,
>         Oscar
>         On Sun, Jan 17, 2010 at 1:08 PM, Oscar Zamudio
>         <cmntlk at gmail.com <mailto:cmntlk at gmail.com>> wrote:
>             Ben,
>             I tried your intruction:
>             UPDATE mypoints SET the_geom = ST_SetSRID(the_geom,4326);
>             But I got:
>             ERROR:  Operation on two GEOMETRIES with different SRIDs
>             Regards,
>             Oscar
>             On Sat, Jan 16, 2010 at 10:48 PM, Ben Madin
>             <lists at remoteinformation.com.au
>             <mailto:lists at remoteinformation.com.au>> wrote:
>                 Oscar,
>                 you have a couple of options as I see it. In Postgres
>                 you could just update the geometries first.
>                 > UPDATE mytable SET the_geom = ST_SetSRID(the_geom,4326);
>                 And for next time, assuming your data originally had
>                 some sort of coordinate system (and it must have if it
>                 was spatial data), you can / should use the -s flag in
>                 shp2pgsql to provide 'SRID awareness'
>                 In your case, I would suggest -s 4326.
>                 ie (using -d to drop and replace existing table
>                 $ shp2pgsql -s 4326 -d myshapefile myoldtablename |
>                 psql mydatabase
>                 In geometry terms, I think it is unlikely that your
>                 data was stored (spatially) as sexagesimal degrees,
>                 although it may be displayed as such in your GIS.
>                 cheers
>                 Ben
>                 On 17/01/2010, at 2:54 , Oscar Zamudio wrote:
>                 > Hi,
>                 > I'm have problems to transform my spatial data to
>                 UTM. First, this instruction works OK:
>                 > SELECT ST_Transform(ST_GeomFromText('POINT(0.0
>                 20)',4326),22171) from mypoints
>                 > No matter if such a sentence has no meaning on what
>                 I tryin to do.  But when I did the same with my own
>                 points:
>                 > SELECT ST_Transform(mypoints.the_geom,22171) from
>                 mypoints
>                 > I get the following error:
>                 > SQL state: XX000
>                 > Ok, when I insert my points in my spatial enabled
>                 database I used:
>                 > INSERT INTO mydistance ( the_geom, the_name ) VALUES
>                 ( ST_GeomFromText('POINT(-58.0 0.0)'), 'Punto 1-1');
>                 > without no spatial reference system explicit so I
>                 guess the SRID is set to "unknown" i.e. -1.  Then
>                 naively I created a new column named srid for my table
>                 and put the right value of SRID for all my data which
>                 is 4326 (WGS84, sexagesimal degrees lat lon) in that
>                 column but still I get the same error. After that I
>                 created a constraint between this new srid column and
>                 the srid column from the spatial_ref_sys table but
>                 nothing happened, the error is still there.
>                 > It's important to me to solve this issue because all
>                 my spatial data was loaded from shapefiles without
>                 SRID awareness so they don't have any SRID column. I
>                 don't want to reload data changing this so I need a
>                 method to alter the tables in such a way to add this
>                 new srid column to them that is well related to the
>                 spatial context.
>                 > Thanks and regards,
>                 > Oscar
>                 > _______________________________________________
>                 > postgis-users mailing list
>                 > postgis-users at postgis.refractions.net
>                 <mailto:postgis-users at postgis.refractions.net>
>                 http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Chris Hermansen · chris.hermansen at timberline.ca · skype:clhermansen
tel+1.604.714.2878   ·  fax+1.604.733.0631   ·   mob+1.778.840.4625
Timberline Natural Resource Group Ltd   ·  http://www.timberline.ca
401  ·  958 West 8th Avenue  ·  Vancouver BC  ·  Canada  ·  V5Z 1E5
