[postgis-users] Questions about using SRID not -1
Oscar Zamudio
cmntlk at gmail.com
Thu Jan 21 09:44:42 PST 2010
Two things. First, the name of the table in the INSERTS sentences is
'mypoints', not 'mydistance'. Second: I tried what Ibrahim suggested:
Select st_xmin(the_geom), st_ymin(the_geom) from mypoints
And the results are:
-58;0
-57;0
-58;-45
-57;-45
-58;-90
-57;-90
So, none of them (as was expected) is out of the geometry projection
reference.
On Thu, Jan 21, 2010 at 2:38 PM, Oscar Zamudio <cmntlk at gmail.com> wrote:
> Hi, me again!
> Well at first it cannot be possible to have more than one projection. For
> clarity, let explain wht I did to reach at this point:
> 1- First I created a database 'mydistances' using postgis_template as
> template for it.
> 2-Create a table 'mypoints' with two columns: 'the_name' and "the_geom"
> 3- Load some GIS data:
> INSERT INTO mydistance ( the_geom, the_name ) VALUES (
> ST_GeomFromText('POINT(-58.0 0.0)'), 'Punto 1-1');
> ST_GeomFromText('POINT(-57.0 0.0)'), 'Punto 1-2');
> ST_GeomFromText('POINT(-58.0 -45.0)'), 'Punto 2-1');
> ST_GeomFromText('POINT(-57.0 -45.0)'), 'Punto 2-2');
> ST_GeomFromText('POINT(-58.0 -90.0)'), 'Punto 3-1');
> ST_GeomFromText('POINT(-57.0 -90.0)'), 'Punto 3-2');
> It can be seen there's no SRID indication and that no value is out of the
> 4326 projection reference.
> 4- Tried to measure distances between those points usin ST_Distance. As all
> those data are in 4326 the retured values are in sexagesimal degrees.
> 5- Tried to use ST_Transform to UTM projections to get the distances in
> meters and all my problems began.
> 6- I want to get the distances in meters reprojecting the points and not
> calculating the meters form the degrees as this calculation depends of the
> UTM zone. I know which zone is in each case and there exists the
> ST_Transform function so, it is easy to avoid additional external
> calculations and obtain directly from the database my results.
> 7- Tried all the recipes I got from you without success.
> Can anybody see what it is the problem with this schema?
> On Thu, Jan 21, 2010 at 4:07 AM, ibrahim saricicek <
> ibrahimsaricicek at gmail.com> wrote:
>> Hi;
>> No you can change projection any time you want, the point on your table
>> is;
>> You have objects in different projections but in one table. You have to
>> find which objects are 4326 projection, and which are not...
>> Another method may be;
>> if the coordinates differ from -->
>> Longitude
>> 180 W = -180
>> 180 E = 180
>> Latitude
>> 90 N = 90
>> 90 S = -90
>> Namely your x not between -180 and 180 and y not between -90 and 90, the
>> objects are in an another projection.
>> I mean firstly try to differ different projected objects..
>> Regards,
>> IBO...
>> On Thu, Jan 21, 2010 at 2:01 AM, Oscar Zamudio <cmntlk at gmail.com> wrote:
>>> Hi,
>>> I tried:
>>> UPDATE mypoints SET the_geom_4326=transform(the_geom,4326)
>>> But again I got:
>>> ERROR: Input geometry has unknown (-1) SRID
>>> It seems that once the data is without explicit SRID, they cannot
>>> be processed later for asigning a proper SRID.
>>> It is strange at first sight....but I'm a newbie so I don't know much
>>> about this.
>>> Regards,
>>> Oscar
>>> On Tue, Jan 19, 2010 at 6:27 AM, ibrahim saricicek <
>>>> Hi,
>>>> Your table include objects, more than one projection.. So if there is
>>>> any object in different projection you can't set your table projection to
>>>> 4326...
>>>> can you try this!!
>>>> Create a new geometry column "the_geom_4326"
>>>> then run this
>>>> UPDATE table_name SET the_geom_4326=transform(the_geom,4326),
>>>> then use ST_SetSRID for the new column...
>>>> REgards,
>>>> ibo...
>>>> On Mon, Jan 18, 2010 at 7:23 PM, Oscar Zamudio <cmntlk at gmail.com>wrote:
>>>>> Hi everybody.
>>>>> I had no success with any of the recipes received here.
>>>>> Could it be that a table with data loaded without SRID explicit value
>>>>> has no chance of being updated later to the right one?
>>>>> Regards,
>>>>> Oscar
>>>>> On Sun, Jan 17, 2010 at 1:08 PM, Oscar Zamudio <cmntlk at gmail.com>wrote:
>>>>>> Ben,
>>>>>> I tried your intruction:
>>>>>> UPDATE mypoints SET the_geom = ST_SetSRID(the_geom,4326);
>>>>>> But I got:
>>>>>> ERROR: Operation on two GEOMETRIES with different SRIDs
>>>>>> Regards,
>>>>>> Oscar
>>>>>> On Sat, Jan 16, 2010 at 10:48 PM, Ben Madin <
>>>>>> lists at remoteinformation.com.au> wrote:
>>>>>>> Oscar,
>>>>>>> you have a couple of options as I see it. In Postgres you could just
>>>>>>> update the geometries first.
>>>>>>> > UPDATE mytable SET the_geom = ST_SetSRID(the_geom,4326);
>>>>>>> And for next time, assuming your data originally had some sort of
>>>>>>> coordinate system (and it must have if it was spatial data), you can /
>>>>>>> should use the -s flag in shp2pgsql to provide 'SRID awareness'
>>>>>>> In your case, I would suggest -s 4326.
>>>>>>> ie (using -d to drop and replace existing table
>>>>>>> $ shp2pgsql -s 4326 -d myshapefile myoldtablename | psql mydatabase
>>>>>>> In geometry terms, I think it is unlikely that your data was stored
>>>>>>> (spatially) as sexagesimal degrees, although it may be displayed as such in
>>>>>>> your GIS.
>>>>>>> cheers
>>>>>>> Ben
>>>>>>> On 17/01/2010, at 2:54 , Oscar Zamudio wrote:
>>>>>>> > Hi,
>>>>>>> > I'm have problems to transform my spatial data to UTM. First, this
>>>>>>> instruction works OK:
>>>>>>> > SELECT ST_Transform(ST_GeomFromText('POINT(0.0 20)',4326),22171)
>>>>>>> from mypoints
>>>>>>> > No matter if such a sentence has no meaning on what I tryin to do.
>>>>>>> But when I did the same with my own points:
>>>>>>> > SELECT ST_Transform(mypoints.the_geom,22171) from mypoints
>>>>>>> > I get the following error:
>>>>>>> > SQL state: XX000
>>>>>>> > Ok, when I insert my points in my spatial enabled database I used:
>>>>>>> > without no spatial reference system explicit so I guess the SRID is
>>>>>>> set to "unknown" i.e. -1. Then naively I created a new column named srid
>>>>>>> for my table and put the right value of SRID for all my data which is 4326
>>>>>>> (WGS84, sexagesimal degrees lat lon) in that column but still I get the same
>>>>>>> error. After that I created a constraint between this new srid column and
>>>>>>> the srid column from the spatial_ref_sys table but nothing happened, the
>>>>>>> error is still there.
>>>>>>> > It's important to me to solve this issue because all my spatial
>>>>>>> data was loaded from shapefiles without SRID awareness so they don't have
>>>>>>> any SRID column. I don't want to reload data changing this so I need a
>>>>>>> method to alter the tables in such a way to add this new srid column to them
>>>>>>> that is well related to the spatial context.
>>>>>>> > Thanks and regards,
>>>>>>> > Oscar
>>>>>>> > _______________________________________________
>>>>>>> > postgis-users mailing list
>>>>>>> > postgis-users at postgis.refractions.net
>>>>>>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100121/295ef3a0/attachment.html>
