[postgis-users] Questions about using SRID not -1
Chris Hermansen chris.hermansen at timberline.ca
Thu Jan 21 10:55:43 PST 2010
Oscar;
Read this:
http://www.postgis.org/documentation/manual-1.4/ch04.html#Create_Spatial_Table
Note the use of the AddGeometryColumn() to put a geometry column on your
table and put an entry in the geometry_columns table, including setting
the SRID correctly.
So your example might be
CREATE TABLE mydistance (the_name text);
SELECT AddGeometryColumn('mydistance','the_geom',4326,'POINT',2);
INSERT INTO mydistance (the_geom, the_name) VALUES
(ST_GeomFromText('POINT(-58.0 0.0)',4326),'Punto 1-1');
etc assuming you wanted SRID 4326.
The next section tells you how to manually register a geometry column if
you have created it manually.
Oscar Zamudio wrote:
> Hi,
> Two things. First, the name of the table in the INSERTS sentences is
> 'mypoints', not 'mydistance'. Second: I tried what Ibrahim suggested:
> Select st_xmin(the_geom), st_ymin(the_geom) from mypoints
> And the results are:
> -58;0
> -57;0
> -58;-45
> -57;-45
> -58;-90
> -57;-90
> So, none of them (as was expected) is out of the geometry projection
> reference.
> On Thu, Jan 21, 2010 at 2:38 PM, Oscar Zamudio <cmntlk at gmail.com
> <mailto:cmntlk at gmail.com>> wrote:
>     Hi, me again!
>     Well at first it cannot be possible to have more than one
>     projection. For clarity, let explain wht I did to reach at this point:
>     1- First I created a database 'mydistances' using postgis_template
>     as template for it.
>     2-Create a table 'mypoints' with two columns: 'the_name' and
>      "the_geom"
>     3- Load some GIS data:
>         INSERT INTO mydistance ( the_geom, the_name ) VALUES (
>         ST_GeomFromText('POINT(-58.0 0.0)'), 'Punto 1-1');
>         ST_GeomFromText('POINT(-57.0 0.0)'), 'Punto 1-2');
>         ST_GeomFromText('POINT(-58.0 -45.0)'), 'Punto 2-1');
>         ST_GeomFromText('POINT(-57.0 -45.0)'), 'Punto 2-2');
>         ST_GeomFromText('POINT(-58.0 -90.0)'), 'Punto 3-1');
>         ST_GeomFromText('POINT(-57.0 -90.0)'), 'Punto 3-2');
>     It can be seen there's no SRID indication and that no value is out
>     of the 4326 projection reference.
>     4- Tried to measure distances between those points usin
>     ST_Distance. As all those data are in 4326 the retured values are
>     in sexagesimal degrees.
>     5- Tried to use ST_Transform to UTM projections to get the
>     distances in meters and all my problems began.
>     6- I want to get the distances in meters reprojecting the points
>     and not calculating the meters form the degrees as this
>     calculation depends of the UTM zone. I know which zone is in each
>     case and there exists the ST_Transform function so, it is easy to
>     avoid additional external calculations and obtain directly from
>     the database my results.
>     7- Tried all the recipes I got from you without success.
>     Can anybody see what it is the problem with this schema?
>     On Thu, Jan 21, 2010 at 4:07 AM, ibrahim saricicek
>     <ibrahimsaricicek at gmail.com <mailto:ibrahimsaricicek at gmail.com>>
>     wrote:
>         Hi;
>         No you can change projection any time you want, the point on
>         your table is;
>         You have objects in different projections but in one table.
>         You have to find which objects are 4326 projection, and which
>         are not...
>         Another method may be;
>         if the coordinates differ from -->
>         Longitude
>          180 W   = -180
>          180 E   =  180
>         Latitude
>           90 N   =   90
>           90 S   =  -90
>         Namely your x not between -180 and 180 and y not between -90
>         and 90, the objects are in an another projection.
>         I mean firstly try to differ different projected objects..
>         Regards,
>         IBO...
>         On Thu, Jan 21, 2010 at 2:01 AM, Oscar Zamudio
>         <cmntlk at gmail.com <mailto:cmntlk at gmail.com>> wrote:
>             Hi,
>             I tried:
>             UPDATE  mypoints SET the_geom_4326=transform(the_geom,4326)
>             But again I got:
>             ERROR:  Input geometry has unknown (-1) SRID
>             It seems that once the data is without explicit SRID, they
>             cannot be processed later for asigning a proper SRID.
>             It is strange at first sight....but I'm a newbie so I
>             don't know much about this.
>             Regards,
>                         Oscar
>             On Tue, Jan 19, 2010 at 6:27 AM, ibrahim saricicek
>             <mailto:ibrahimsaricicek at gmail.com>> wrote:
>                 Hi,
>                 Your table include objects, more than one projection..
>                 So if there is any object in different projection you
>                 can't set your table projection to 4326...
>                 can you try this!!
>                 Create a new geometry column "the_geom_4326"
>                 then run this
>                 UPDATE  table_name SET
>                 the_geom_4326=transform(the_geom,4326),
>                 then use ST_SetSRID for the new column...
>                 REgards,
>                 ibo...
>                 On Mon, Jan 18, 2010 at 7:23 PM, Oscar Zamudio
>                     Hi everybody.
>                     I had no success with any of the recipes received
>                     here.
>                     Could it be that a table with data loaded without
>                     SRID explicit value has no chance of being updated
>                     later to the right one?
>                     Regards,
>                     Oscar
>                     On Sun, Jan 17, 2010 at 1:08 PM, Oscar Zamudio
>                         Ben,
>                         I tried your intruction:
>                         UPDATE mypoints SET the_geom =
>                         ST_SetSRID(the_geom,4326);
>                         But I got:
>                         ERROR:  Operation on two GEOMETRIES with
>                         different SRIDs
>                         Regards,
>                         Oscar
>                         On Sat, Jan 16, 2010 at 10:48 PM, Ben Madin
>                         <lists at remoteinformation.com.au
>                         <mailto:lists at remoteinformation.com.au>> wrote:
>                             Oscar,
>                             you have a couple of options as I see it.
>                             In Postgres you could just update the
>                             geometries first.
>                             > UPDATE mytable SET the_geom =
>                             And for next time, assuming your data
>                             originally had some sort of coordinate
>                             system (and it must have if it was spatial
>                             data), you can / should use the -s flag in
>                             shp2pgsql to provide 'SRID awareness'
>                             In your case, I would suggest -s 4326.
>                             ie (using -d to drop and replace existing
>                             table
>                             $ shp2pgsql -s 4326 -d myshapefile
>                             myoldtablename | psql mydatabase
>                             In geometry terms, I think it is unlikely
>                             that your data was stored (spatially) as
>                             sexagesimal degrees, although it may be
>                             displayed as such in your GIS.
>                             cheers
>                             Ben
>                             On 17/01/2010, at 2:54 , Oscar Zamudio wrote:
>                             > Hi,
>                             > I'm have problems to transform my
>                             spatial data to UTM. First, this
>                             instruction works OK:
>                             > SELECT
>                             ST_Transform(ST_GeomFromText('POINT(0.0
>                             20)',4326),22171) from mypoints
>                             > No matter if such a sentence has no
>                             meaning on what I tryin to do.  But when I
>                             did the same with my own points:
>                             > SELECT
>                             ST_Transform(mypoints.the_geom,22171) from
>                             mypoints
>                             > I get the following error:
>                             > SQL state: XX000
>                             > Ok, when I insert my points in my
>                             spatial enabled database I used:
>                             the_name ) VALUES (
>                             'Punto 1-1');
>                             > without no spatial reference system
>                             explicit so I guess the SRID is set to
>                             "unknown" i.e. -1.  Then naively I created
>                             a new column named srid for my table and
>                             put the right value of SRID for all my
>                             data which is 4326 (WGS84, sexagesimal
>                             degrees lat lon) in that column but still
>                             I get the same error. After that I created
>                             a constraint between this new srid column
>                             and the srid column from the
>                             spatial_ref_sys table but nothing
>                             happened, the error is still there.
>                             > It's important to me to solve this issue
>                             because all my spatial data was loaded
>                             from shapefiles without SRID awareness so
>                             they don't have any SRID column. I don't
>                             want to reload data changing this so I
>                             need a method to alter the tables in such
>                             a way to add this new srid column to them
>                             that is well related to the spatial context.
>                             > Thanks and regards,
>                             > Oscar
>                             _______________________________________________
>                             > postgis-users mailing list
>                             > postgis-users at postgis.refractions.net
>                             <mailto:postgis-users at postgis.refractions.net>
>                             http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Chris Hermansen · chris.hermansen at timberline.ca · skype:clhermansen
tel+1.604.714.2878   ·  fax+1.604.733.0631   ·   mob+1.778.840.4625
Timberline Natural Resource Group Ltd   ·  http://www.timberline.ca
401  ·  958 West 8th Avenue  ·  Vancouver BC  ·  Canada  ·  V5Z 1E5
